Old 09-12-2009, 01:22 PM   #1 (permalink)
Brian87gt's Avatar
Member Number: 4097
Default Do I have to have a checkvalve?
I'm wont be getting my new checkvalve until monday. The older style plastic one I had was leaking, which would explain the sudden change in my AFR's under WOT. Is it safe to run it straight from the pump to the nozzle without a check vavle until I get the new one? Thanks
Brian87gt is offline   Reply With Quote
Old 09-12-2009, 02:44 PM   #2 (permalink)
Mana4real's Avatar
Member Number: 25021
I would very much advise against it.
-Matt- -SCT Tuned- By Yours Truely
Old 09-12-2009, 03:30 PM   #3 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Your motor is gonna suck off your meth
Vacuum = suck it all up
or 16 whatev
WTB: LCA bushings
Old 09-12-2009, 03:48 PM   #4 (permalink)
Turbolag87's Avatar
Member Number: 6491
ive been running no check valve for 4 yrs.
F&F Stage III 47lb turbo
Returnline
AGP WGA,
Rolling thunder Race head
11.40@125mph 26psi and no boost leak
New times with new race head coming soon
Turbolag87 is offline   Reply With Quote
Old 09-12-2009, 04:36 PM   #5 (permalink)
Adionik's Avatar
Trader Rating: (25)
Interesting, because my friend had one and it sucked it all dry...with 12afrs and the car would stay running
Old 09-12-2009, 05:18 PM   #6 (permalink)
Turbolag87's Avatar
Member Number: 6491
my car does suck in some water only when i Dont screw on the tank cap very tightly. It was amazing how much stronger it sprayed without my checkvalve, it was unreal.
Old 09-14-2009, 10:35 PM   #7 (permalink)
Member Number: 59344
The pump has to overcome the checkvalve. If you have a 100 psi pump, then you lose 1/4 of that to the check valve, plus whatever you are boosting.
Dust is offline   Reply With Quote
Old 09-15-2009, 12:06 AM   #8 (permalink)
Turbolag87's Avatar
Member Number: 6491
Ya i know it how works, i just dint realize how much of a difference it made physically with my own eyes. I have the 150psi old school pump but im thinking of upgrading to the 250psi
Old 09-15-2009, 01:48 AM   #9 (permalink)
Not trying to insult. More for everyone than just you, for those who didn't know.
Old 09-15-2009, 03:58 PM   #10 (permalink)
Member Number: 72597
When I ran without a checkvalve, after I turned off the car, the next morning I went out to start it, and all the meth had drained past the pump and into the intercooler pipe, emptying the tank, and making the car undriveable.
RaggedEdge is offline   Reply With Quote
Old 09-15-2009, 07:10 PM   #11 (permalink)
Turbolag87's Avatar
Member Number: 6491
none taken no worries
Old 09-15-2009, 08:43 PM   #12 (permalink)
Member Number: 53360
Brian, my check valve got something stuck in it and held it open and sucked meth like a Jeff Co dope head. Just cruising around the a/f was 10.0-11.0 on the way home when it happened.
Also Gary didnt put one in on his car and it drank his entire tank in just a few minutes at idle. Thats with d/p of course.
2004 SRT-4 Murdered, Built, Cammed, GT35R, Meth, N2O
2003 Dakota R/T Charcoal, Stock
mjennings2 is offline   Reply With Quote
Old 09-23-2009, 07:30 AM   #13 (permalink)
Turbolag87's Avatar
Member Number: 6491
u guys jinxed me, now everytime i go to start my car its sucking up at least a liter of water everytime i start it (good for cleaning my head lol) Who sells the lowest cracking point check valve around?
Old 10-15-2009, 11:20 PM   #14 (permalink)
Member Number: 52407
Run a solenoid, would that eliminate the pressure drop of the checkvalve?
7055 is offline   Reply With Quote
Old 10-16-2009, 05:43 PM   #15 (permalink)
SonnySrt-4's Avatar
Member Number: 34315
Trader Rating: (10)
yes it will... I used to run it with a noid and it felt better and had i had less issues.
Edited by Inzanesrt4
Agp s3d-44lb turbo kit
38mm TurboSmart Wga
3inch bdj's catless down pipe dumped exhaust
BFMIC
N2MB Boost box (GET ONE!!!)
D/O Meth/Alchy injection m5
DSP tuner
800cc injectors
HKS bov and hard pipe
SonnySrt-4 is offline   Reply With Quote
Page generated in 0.17055 seconds with 13 queries
