Old 04-16-2008, 04:53 PM   #1 (permalink)
khock3's Avatar
Member Number: 39741
Trader Rating: (12)
Default devils own problem
I just installed 3 bar map and tip sensors and now when I turn the key all the way back to ACC the kit starts pumping...WTF anybody have any ideas how to fix this?
khock3 is offline   Reply With Quote
Old 04-16-2008, 04:54 PM   #2 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (18)
Sounds like you wired the relay wire to the ACC circuit.
HCCAFan is offline   Reply With Quote
Old 04-16-2008, 05:17 PM   #3 (permalink)
khock3's Avatar
Trader Rating: (12)
the thing is, it never happened when I had the stock 2 bar sensors in.
Old 04-16-2008, 05:18 PM   #4 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
My devilsown kit runs off boost pressure. Yours takes a signal off the MAP?
Old 04-16-2008, 05:23 PM   #5 (permalink)
khock3's Avatar
Trader Rating: (12)
yea it reads off the map sensor
http://www.alcohol-injection.com/pro...uctions_vc.pdf
Old 04-16-2008, 10:07 PM   #6 (permalink)
smokin-ricers's Avatar
Member Number: 10183
Trader Rating: (10)
this is what Chance sent me on how to change a 2 bar controller to a 3 bar controller try this out it is kinda hare to get it right but it worked on mine
Quote: Originally Posted by chance@devilsown
Connect the ground to ground
To go to 2 bar the start position dial must be to the left of 12 o'clock.
To go to 3 bar the start position dial must be to the right of 12 o'clock
The easiest way to do this is to have the blue wire in one hand and the red in the other.
Take the blue wire and touch it to the 12v source. Let it flash whatever mode it is in.
Leave it connected to the source. Take the Red wire touch it to 12v source. The 3rd LED will start to flash slowly.
As soon as you see this tap the blue wire 2 times on the 12v source. You will see the 3rd LED flicker. As soon as it flickers it is in reprogramming mod. Let it do it's thing untill you see it flash 3 times then 3 times.
They you will be done.
I am STOCK
Ya know what I mean
DevilsOwnOnline
smokin-ricers is offline   Reply With Quote
Old 04-16-2008, 11:33 PM   #7 (permalink)
FraziersSRT's Avatar
Member Number: 37867
Trader Rating: (46)
Hmmm...might want to contact Devils Own and talk to somebody over there.Beats me...
WTB : BORG WARNER S256 TURBO,GT30R OR DBB 50 TRIM - PM ME CASH IN HAND!!!
FraziersSRT is offline   Reply With Quote
Old 04-17-2008, 07:21 AM   #8 (permalink)
khock3's Avatar
Trader Rating: (12)
Yea I already recalibrated the controller. I think I am going to call Devils Own today to see if they can help me.
Old 04-17-2008, 10:02 PM   #9 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
What you find out?
Old 04-20-2008, 09:45 AM   #10 (permalink)
chance@devilsown's Avatar
Member Number: 35658
Trader Rating: (30)
If its turning on sproaticly when power is applied to the controller the green wire of our controller is not properly attached to the map sensor signal wire.
You should also make sure you have the controller in 3 bar mode. It will blink 3 times at startup. Remember when using a 2 bar "face plate" when the controller is in 3 bar mode the numbers are going to read off. So you might just have the turn on too low also.
chance@devilsown is offline   Reply With Quote
Page generated in 0.16734 seconds with 11 queries
