Old 08-27-2007, 04:12 PM   #31 (permalink)
Member Number: 51090
Quote: Originally Posted by Coolingmist
Our valve is not made by clippard, our valve is 430F stanless steel. The valve that Aquamist is experimenting with is a very cheap valve made by clippard for use in air application. Its designed with CRS (cold rolled steel, commonly refered to as "junk steel"). It has great magnetic properties, but poor corrosion resistance. Clippard puts a .004 coating of Nickel, but obviously over time and with any abrasion that will wear thin and you will see corrosion.
That manifold that you see (the "aluminum" has a thick coating of Nickel to prevent corrosion of methanol and he is running 100% water anyway).
Let me know if that satisfies your audit.
David
http://www.clippard.com/downloads/ge...l%20Valves.pdf
is the company you are getting your pwm valve not worried that they will get sued by clippard for copying their patented spider design?
6 injectors, 3 fuel tanks and 2 fuel pumps
3" TBE, MBC@26psig peak
Aquamist methanol injection + DDS3 failsafe - http://forums.evolutionm.net/showthread.php?t=239686
JESTR tuned - gained 100TQ / 80HP - http://www.putfile.com/pic.php?img=4564538
SlowCar is offline   Reply With Quote
Old 08-27-2007, 04:18 PM   #32 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (50)
David
Dude,
You are a little clueless. In a few weeks you may realize what I already know. Until that time, have your fun.
Old 08-27-2007, 04:24 PM   #33 (permalink)
OTownSRT4's Avatar
Member Number: 38911
Trader Rating: (13)
David
Oh and Slowcar GTFO, take your BS elsewhere.
OTownSRT4 is online now   Reply With Quote
Old 08-30-2007, 09:12 AM   #34 (permalink)
Member Number: 30703
David
Otown, what size nozzles did you end up using in this setup?
Stg 2 'n stuff - 13.24@109.7 street tires.
agp S3D 48# numbers to come soon.
harvboi05 is offline   Reply With Quote
Old 08-30-2007, 09:49 AM   #35 (permalink)
OTownSRT4's Avatar
Trader Rating: (13)
I believe they're M2's.....I haven't really tuned the system in as I am STILL waiting on many other things to be completed. To be honest my system hasn't even been turned on in months.
Old 08-30-2007, 10:10 AM   #36 (permalink)
Member Number: 56271
Thats Crazy.
Thats Crazy is offline   Reply With Quote
Old 09-04-2007, 07:53 PM   #37 (permalink)
cali's Avatar
Member Number: 159
Clippard doesnt make the valves....uh huh..you got the right one baby...
So is Aqua gonan release an el-cheapo kit using the clippard valves?
someone is watching me
Old 09-04-2007, 10:48 PM   #38 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (60)
Ok, this is sick, we sold this on Friday to a hot rodder. Only coolingmist would do. He actually had another kit which he waited from England for ever, but ended up sending it back and using ours. Its our first 8 port S-HSV. Notice the manifold....
*eight* port
how well do they flow?!
SCT Tuned by Kevin@AGP Turbo
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 09-05-2007, 06:20 AM   #39 (permalink)
Trader Rating: (50)
8 ports, 1.3 GPH each=roughly 10 GPH, which is the valves sweet spot.
Old 09-18-2007, 09:55 AM   #40 (permalink)
Member Number: 17858
This would fit on my new car perfectly.....
Grifter is offline   Reply With Quote
Old 09-27-2007, 07:33 PM   #41 (permalink)
05redSrtfour's Avatar
Member Number: 54938
Trader Rating: (20)
still tryin to decide between the direct port or before the tb. i've read where when you put the sprayer be4 the IAT(sensor in the hp) it reads cooler and gives you more performance. is even distribution the only advantage of dp?
12.87 @ 108 1.98 60ft
JMB Ultimate CAI, B&B TBE, AGP Hardpipes w/Hks BOV, AGP upgraded WGA, Tein S-Tech's, AEM Truboost, AEM wideband, M&H Slicks, **Added after 12.87** AEM EMS, AGP Return line, DW 750cc inj., Fuel Pump, Rewire, Bottleneck, Coolingmist Direct Port meth inj., AGP Race FMIC, FBM Ported/ Ceramic Exhaust Manifold, Maxxfab 3" 02 Housing. PTP S3K Turbo.
05redSrtfour is offline   Reply With Quote
Old 09-27-2007, 07:39 PM   #42 (permalink)
Trader Rating: (50)
even distribution and obviously it has to be somewhat faster even if marginal. The nozzles will be smaller, you will use a little less water and maybe have slightly better atomization as well.
Old 06-19-2008, 08:19 PM   #43 (permalink)
FraziersSRT's Avatar
Member Number: 37867
Trader Rating: (34)
Not only did you purchase and build a custom direct port methanol kit,but you also fab'd a REAL twin turbo setup.If I had the money you had,I would probably turn my car into a damn airplane,lol. Great work man,keep it up!
-Frazier
~P.S. What are the gains with this setup versus a regular methanol setup?
FS : RC 650's $200.00 SHIPPED!!
http://www.srtforums.com/forums/f27/...5/#post6142045
FS : Mopar Turbo Back Exhaust w/cutout!! $350.00!!
http://www.srtforums.com/forums/f27/...8/#post6171626
WTB : CRANE 14'S,44LB S3 TURBO,DTEC FC BC AND S3 PCM!! PM ME!!
FraziersSRT is offline   Reply With Quote
Page generated in 0.29712 seconds with 11 queries
