Old 09-21-2009, 10:46 PM   #1 (permalink)
Fatal1tyKn1ght's Avatar
Member Number: 63764
Default Coolmist Trunk Mount (Mounting Location)
I bought the coolingmist setup - I'm looking for locations to mount the tank. One idea I thought of would be to mount it vertically on the seat back. (pull the seat down to fill it, put the seat back up for use) I'm wondering if this would work?
I wasn't sure if the pump needed to lay horizontal for any specific reason. I did a search, but haven't seen this setup or an answer to this question.
Mopar BOV, Mopar STS, Mopar Stage 1 ECU, BWoody Oil Catch Can, K&N Drop-In Filter, Needswings 3" DP w\Cutout, Maxxfab 3" O2 Housing, SAFCII, FM WGA, AEM Wideband, Aeroforce Scan Gauge, Magnecor Wires, NGK V-Power Plugs, Prothane Motor Mount Inserts, DC Sports Front\Rear Strut Bars, Mopar Stage 2\3 Injectors, Walbro 255 Fuel Pump, Coolingmist Methanol Injection
Fatal1tyKn1ght is offline   Reply With Quote
Old 09-22-2009, 01:12 PM   #2 (permalink)
Member Number: 52407
There are two grommets in the trunk at the rear on either side. I mounted mine off to the left side so it's out of the way of anything I want to throw in the trunk. The lines run down through that grommet.
7055 is online now   Reply With Quote
Old 09-22-2009, 02:52 PM   #3 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
7055, bro that looks pretty in the way if you ask me!
bribri is offline   Reply With Quote
Old 09-22-2009, 06:19 PM   #4 (permalink)
I guess maybe it's not clear what I'm asking. I have two SUBS in the rear of my car, so room is limited. My METH tank I wanted to mount on the SEAT BACK. I didn't know if this would affect how the pump worked or if the cap was sealed. I received my kit today, it does appear there is a small hole in the cap, I'm guessing this is so air can release as the pump is taking in the METH. This is for the coolingmist setup, I've already seen DO kits mounted to the seat back, but this is an entirely different setup.
Old 09-22-2009, 06:39 PM   #5 (permalink)
I'd mount a normal tank on the seatback but not a trunkmount. Shoot if you fill it up 2/3 of the way it'll be leaking out the cap if it's mounted vertically. Besides I don't think the straps can hold the trunkmount when it's full of fluid if it's mounted on a vertical wall.
Old 09-22-2009, 06:53 PM   #6 (permalink)
Yeah you're right - I thought the container was leak proof. This would have been a cool setup. This is what I was going for.
But now I'll be doing the trunk mount in the very back section
Old 09-22-2009, 06:55 PM   #7 (permalink)
You could just get a normal tank. It would still leak out the hole in the cap when you lowered the seatback but you could mount it elsewhere or just not lower the seat back.
Old 09-22-2009, 07:07 PM   #8 (permalink)
Nah, I'm just going this route.
Thanks for your input man, I appreciate it.
Old 09-25-2009, 12:08 AM   #9 (permalink)
NightRiderSRT4's Avatar
Member Number: 47673
Trader Rating: (20)
I mounted mine in the spare tire well....I;ll post pics tomorrow
SCT TUNED / AGP 50trim .63ar, coolingmist varicool meth injection, stage 2 w/o toys, ED SEE catless/resonatorless, mopar CAI, Greddy RS bov, JRE BFMIC/harpipes, Walbro 255, RC 750s, DC front strut bar, PTP Stage 3 Clutch,,Forge MBC, AGP dog bone MM,BC Coilovers,aem uego,oil pressure,volt gauges
Project 400whp
NightRiderSRT4 is offline   Reply With Quote
Old 09-25-2009, 02:05 AM   #10 (permalink)
cool waitin for the pics
Old 09-25-2009, 01:51 PM   #11 (permalink)
Member Number: 31038
Trader Rating: (50)
No its not. If it was msack dab in the middle I could see it being int he way, but its off to the side.
Looks good man.
raul-01 is online now   Reply With Quote
Old 09-25-2009, 03:00 PM   #12 (permalink)
thanks yo, I might have put it smack dab in the middle if it weren't for the fact I can take everything home from college in my stripped car including my bike and do so occasionaly. And the fact that I'd have to make the line/wires run through the car or else double back and do a 180.
Old 09-25-2009, 03:29 PM   #13 (permalink)
Mine's kind of an ugly duckling with the loose wiring and stripped carpet lol. That one above looks clean though. I wonder how he mounted it without the straps.
Old 09-27-2009, 04:35 PM   #14 (permalink)
Roadkill's Avatar
Member Number: 24241
Trader Rating: (19)
Where i mounted mine
12.33@114.36 21 psi and stock clutch
334whp 353ft-lb
External Stg3 turbo+bolt ons
Roadkill is offline   Reply With Quote
Old 09-28-2009, 11:12 AM   #15 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Bitts has his mounted to the seat. Very clean and easy to add meth...
or 16 whatev
WTB: LCA bushings
Adionik is online now   Reply With Quote
Page generated in 0.18611 seconds with 13 queries
