Old 04-24-2007, 06:11 PM   #106 (permalink)
EricP's Avatar
Member Number: 22154
FIXED
Sorry the first one was done from memory, I should have looked at my setup first.
Stock Turbo
WHP:283 WTQ:334
EricP is offline   Reply With Quote
Old 04-24-2007, 08:09 PM   #107 (permalink)
BTR
BTR's Avatar
Member Number: 11347
Trader Rating: (43)
Quote: Originally Posted by Coolingmist
I dont know what you have from us. The float switch is simple. Use the red wires as a ground for your LED. Take your led and hook one end to any power source, hook the other to one of the red wires on the float switch, hook the other end to a chasis ground.
If you have our status monitor, use the status monitor as the ground to your LED, same concept.
let me know if you need more guidance.
CM
i have the standard trunk mount kit from the GB
BTR is offline   Reply With Quote
Old 04-24-2007, 08:45 PM   #108 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
Quote: Originally Posted by EricP
FIXED
i think thats 99% correct.
i think that the low level switch works totally independent of the pump (in your illustration it looks like its connected to the pump)
Old 04-24-2007, 09:10 PM   #109 (permalink)
EricP's Avatar
FIXED
The only thing that the pump and the LED share is a ground. It's usually best to get more than one thing to share a ground, plus it makes it easier to run them both to the same spot.
Old 05-24-2007, 08:45 PM   #110 (permalink)
b00stLEAK's Avatar
Member Number: 54308
Ordered the kit yesterday and it arrived today. Thanks for taking the time to answer my questions on the phone,and the fast shipping, can't wait to hook it up -Jonathan
Boosted05 is now b00stLEAK...LOL its still the same POS car though
S1/QUICKWHIPS FMIC/KINETIC 55MM TB/JMB UPP/LPP/HKS SSQ BOV/PTP WG/17PSI/MADDOG 80% SS/30/30 CF BG/INJEN DP/CUSTOM 3'' SEE/GROUNDING KIT/MSD 8.5 WIRES/NGK IRIDIUMS.35/DASMOPAR MAP CLAMP/UPPER STUTBAR/EIBACH SPRINGS/AGP DOGBONES/UPP/LOWER/COOLING MIST W/I/TURBO XS DSMBC/180 TSTAT
b00stLEAK is offline   Reply With Quote
Old 05-25-2007, 10:51 AM   #111 (permalink)
parsonsproject's Avatar
Member Number: 14704
FIXED
Anyone else confirm this drawing? Looks like the standard trunkmount kit comes with the low fluid switch, but does that include the LEDs? For low fluid or pump spraying?
<-- 2007 coSRToc dyno competition winner, stock turbo class [298whp/344wtq] on 91 pump, 50/50 w/m, untuned stg1-->
(DS Trinity tuned, new #'s and win to come)
parsonsproject is offline   Reply With Quote
Old 05-26-2007, 03:59 PM   #112 (permalink)
Member Number: 50913
how do you know what size nozzle you get with the kit? just got my CM standerd kit on . seems to be working fine, just wondering what size nozzle i had. (350-400hp)
stage2,safc2,DSP,Garret 60-1,Hahn mani,atp 3"o2,QTP 3" dp w/dump, 4" sri,ported IM/TB,ED "beast" fmic,AGP/Turbonetics hp's, Whalbro255,AGP rL kit, RC 750's, CM w/m injection, 180 therm., catch cans,Granitelli wires, NGK plugs, AGP wga,Gizmo ebc, "raptor" bov, mm inserts,WR torque damper, Spec stage3clutch/flyweel, b/s chain cut, PLX wideband, Autometer(boost45psi,volts,oil)scanguage, NDE TSC box
---whp,---wtq
vcious is offline   Reply With Quote
Old 05-26-2007, 04:10 PM   #113 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
yours would be about 6.2 GPH.
CM
Old 05-26-2007, 04:41 PM   #114 (permalink)
wow, that was fast. thanks. one more ? what are these other nozzles everyone else talks about( m5,m7,ect.)? are they for a different CM kit?
Old 05-26-2007, 04:49 PM   #115 (permalink)
Trader Rating: (64)
M5= 5 GPH @ 100 or 6.2 GPH @ 150
M7=7 GPH @ 100
The number next to the M is the GPH rating @ 100 psi.
Thanks!
Old 05-26-2007, 05:08 PM   #116 (permalink)
oh....thanks.
Old 05-31-2007, 06:35 PM   #117 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (115)
If I want to order a controller to do more fine tuning later this summer at a later date can I put it on the basic kit I just ordered?
AGP Delta55 123mph pump low boost, 127 race gas and low boost.
addictedtosin is offline   Reply With Quote
Old 05-31-2007, 06:40 PM   #118 (permalink)
Trader Rating: (64)
absolutely!
CM
Old 05-31-2007, 07:00 PM   #119 (permalink)
EricP's Avatar
This is correct, this is how mine is wired up and it works perfectly
This is for the standard trunk mount kit and it does come with a low level indicator. However it does not come with LED's so you will have to pick some up from an auto parts store or order some off the internet.
Old 05-31-2007, 08:47 PM   #120 (permalink)
absolutely!
CM
Excellent, thx
« stock intercooler | - »
Page generated in 0.18700 seconds with 13 queries
