Old 11-04-2009, 06:17 PM   #976 (permalink)
Chief's Avatar
Member Number: 61336
Yea i just need to make sure i put the right fittings in to work with the stock pump hardware?
Names Josh Matteson
Built bottom end
strapped BC and CP
HTA 60
PTP when you fedex man gettin this block?
Chief is offline   Reply With Quote
Old 11-04-2009, 10:18 PM   #977 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
The one you ordered has the same identical ports and mounting plate, its a drop in replacement.
Thanks again!
Old 11-04-2009, 10:19 PM   #978 (permalink)
Chief's Avatar
NICE! thanks dave. Cant wait
Old 11-04-2009, 11:22 PM   #979 (permalink)
SRToad4's Avatar
Member Number: 61889
How do you know when you have maxed out the stock pump, and are ready to upgrade to the 250psi pump?
Tuned by Tony @ UMS Tuning
390whp/380tq @ 21.5psi / 91 + Meth
SRToad4 is offline   Reply With Quote
Old 11-04-2009, 11:34 PM   #980 (permalink)
Chief's Avatar
idk... mine sprung a leak... its time. lol
Old 11-04-2009, 11:48 PM   #981 (permalink)
SRToad4's Avatar
haha that works too!
Old 11-05-2009, 12:34 AM   #982 (permalink)
Chief's Avatar
with the M10 the 150 would never pulse, guessing it would never make 150 psi, it was just to big of a nozzle for the 150. Im sure 250 it will be no problem. But dave am i correct when i say the 250 will not pulse? So how do you know if its really reaching peak psi? I knew with the 150 cause it would pulse.
Old 11-05-2009, 02:59 AM   #983 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
have a little problem(maybe)
the nozzle isnt really tight on the intercooler pipe as it used to be.I took it out couple of times to make sure it was clogged as well to clean it.not when i try to screw it back in,it just pops in,as the hole got bigger..any fixes on that?I wouldnt be surprised if there was a boost leak there.I tapped it with duct tape so it stays in there and doesnt leak when under boost.kinda ghetto
BIG TURBO!
Old 11-05-2009, 06:30 AM   #984 (permalink)
Trader Rating: (64)
put pipe tape on the injector, that should solve it.
CM
Old 11-05-2009, 09:46 AM   #985 (permalink)
SRToad4's Avatar
How hard do I have to push down on the orange rings to get the quick release to worK? It seems like no matter how much I pull the line, or push down on the ring, the line won't come out. Is there a trick to it?
Old 11-05-2009, 11:32 AM   #986 (permalink)
Trader Rating: (64)
If there is pressure in the line you will need to loosen the fitting before you can remove.
Having said that, here are a few tricks.
1) take an adjustable wrench and put the hose between the teeth of the wrench and close the wrench until its just touching the hose and then move down until its pressing against the orange clip. Pull up on the hose and push on the wrench. It will release the hose easy.
2) if you dont have one you can take a screw driver and press in on the slit that you will see in the orange clip and pull out on the hose. Just becareful not to slip the wrench and damage something. This is why I like option #1 better.
CM
Old 11-05-2009, 09:08 PM   #987 (permalink)
Xx_R/T_xX's Avatar
CM
well that didnt work.had it on there,hit full boost and heard some metal hiting under the car.i come out and find out the nozzle came off and disappeared..so now i need tobuy a new nozzle..booo
Old 11-05-2009, 09:52 PM   #988 (permalink)
Trader Rating: (64)
Did you tap this into metal or install into your rubber hose?
Old 11-06-2009, 12:16 AM   #989 (permalink)
morgantj13's Avatar
Member Number: 47175
go back and look for it lol
Old 11-06-2009, 01:56 AM   #990 (permalink)
Xx_R/T_xX's Avatar
tapped it directly into the aluminum intercooler pipe.guess im gonna have to get a bung and get it welded onto the intercooler pipe..also as far as damage goes,the check valve and part of the nozzle were dragged on the floor for about 10seconds..they still had some meth in them,but luckly i wasnt boosting.checkvalve and nozzle are totally destroyed from road rash.
i got lucky there wasnt any spark action from the checkvalve draggin on the floor or i would of been on fire
Im running mid 400whp.wat nozzle would work good for me.m5,m6, or m10?
and what bung do i need to order so i can weld it onto my agp intercooler pipe and than thread the nozzle in it
Page generated in 0.19219 seconds with 13 queries
