Always remember you can add the flow sensor to your VC2 at any time. Most customers that order later realize that they were driving blind without it. If any of your nozzles clog or partially clog the flow rate will change.
KNowone wants the old cari cool controllers with these out now
what if we did something like....
order a CMGS and flow sensor and get a 250 psi pump free...
or order a cmgs and get a 250 psi pump 1/2 off. We were thinking about running something like this for our srt members, but im not sure there is enough that would want to upgrade to do this. Most that are looking are looking for a kit.
I have a cmg controller and was wondering if theres a way to wire in a led light to tell me when the injection starts. I had the led wired when i just had the boost switch and would like to still use the same led. Thanks
you can actually do it within the controller itself. There is a light called "fault". It will light up when its grounded. There is an AUX ground wire that turns on when you hit the MIN setting. so if you take the 22 gauge green wire and connect to the 22 gauge yellow wire, it will light up the fault light when you hit your MIN setting.
Otherwise, use the 22 gauge yellow wire as the ground for your led. Take your led give one end power and then connect the other end (ground end) to the 22 gauge yellow wire.
Thats your choice. I would leave it within the gauge as its more simple and you dont need another led.
Is there any way to know specifically which nozzle came with my car from my kit I got off ebay? I remember calling and including in the notes I wanted an M5 or so, but I never got any confirmation or anything with the actual kit. Nozzle looks small as hell.
Would be sweet bro,BUT got alot on the list before upgrading my meth system.
Will the cooling effects of water/methanol lower my gauge indicated boost pressure? Makes sense, cooler air means lower pressure. My results seem to indicate this but I can't tell with all the variables.
no. you should see no boost increase unless you are spraying pre-turbo.
That sucks, 'cause I just ordered that and would've loved to have picked up a 250 psi pump. Ehh... what'cha gonna do?!
