Old 07-09-2009, 07:47 AM   #721 (permalink)
Chief's Avatar
Member Number: 61336
get a bigger nozzle M8 or M10. what kinda mix are you running too?? Please dont say windshield washer fluid. Get REAL meth mix 50/50 by WEIGHT if still getting kicked out try 100% Meth im SURE you will not get kicked out of HOM. if you DO BIGGER NOZZLE!!!
Built
HTA 60
"Shes hunting unsuspecting Evo's and Sti's in their natural environment..."
Chief is offline   Reply With Quote
Old 07-09-2009, 06:54 PM   #722 (permalink)
EvilSRTMo's Avatar
Member Number: 49027
I'm kinda new to this meth stuff but im running 75% water 25% meth
EvilSRTMo is offline   Reply With Quote
Old 07-10-2009, 01:19 PM   #723 (permalink)
Chief's Avatar
just went to 100% meth, can run at half duty cycle and have the same afrs and no knock. Does richen up quite a bit, but still gonna need some 750's for my set up. M10 at 50% cycle runs great.
Old 07-17-2009, 03:06 PM   #724 (permalink)
Member Number: 38712
Are there any limitations or necessities on the mounting position of the 250psi pump?
Tjabo is offline   Reply With Quote
Old 07-17-2009, 03:07 PM   #725 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (68)
if you are running a checkvalve it needs to be gravity fed nothing other than that
CM
Old 07-17-2009, 03:13 PM   #726 (permalink)
Solenoid here, so I guess I can mount it however I can fit it, huh?
Old 07-17-2009, 03:24 PM   #727 (permalink)
Trader Rating: (68)
should be fine.
Old 07-20-2009, 03:52 PM   #728 (permalink)
Aceburner's Avatar
Member Number: 52066
Trader Rating: (13)
I just bought your standard trunk mount kit.... b4 the install, would you suggest some sort of LED to let me know when the pump is spraying and maybe some kind of kill switch?
Aceburner is offline   Reply With Quote
Old 07-20-2009, 04:34 PM   #729 (permalink)
Trader Rating: (68)
hi. If you want a LED or kill switch you can pick one up at radioshack. They sell them both for a few bucks.
any more questions let me know.
David
Old 07-20-2009, 06:53 PM   #730 (permalink)
Aceburner's Avatar
Trader Rating: (13)
David
How do u actually wire them into the setup?
Old 07-20-2009, 07:38 PM   #731 (permalink)
Trader Rating: (68)
you can use the switch as the ground for the pump.
for the led, take one end and give your ground, take the other and connect to the NO port of the boost switch.
David
Old 07-20-2009, 08:01 PM   #732 (permalink)
Aceburner's Avatar
Trader Rating: (13)
So, I will hook the pump ground directly into the switch and hook the LED into a ground and the other end into the NO port on the boost switch?
Old 07-20-2009, 08:10 PM   #733 (permalink)
Trader Rating: (68)
yes. Wire the switch inline with the ground of the pump and do the LED thing as discussed.
Old 07-21-2009, 06:59 PM   #734 (permalink)
Aceburner's Avatar
Trader Rating: (13)
I have another question, I have a sound system in my trunk, would this affect the kit in anyway? Does the standard still come with the fluid level thing I was reading about?
Old 07-21-2009, 07:49 PM   #735 (permalink)
Trader Rating: (68)
The low level fluid switch is optional on all kits.
Our systems will not be affected by your sound system. Just make sure if the tank is the back that you dont have any leaks.
CM
