And what ground is the 22 gauge black wire for? The diagram just says ground, I need to know if it's neccessary wire for me. Does it have something to do with the flow sensor or low level sensor, if so I'm not using either. Thanks
Question about Varisafe's 0-5V programmable output
Hi David,
My current setup is a Varisafe that has the 0-5V output programmed with a RPM/MAP 8x8 grid. The output is clamped to 0 when the TPS is lower than 2.8V. The output is wired to a Varicool that injects only based on the 5V output. I got 2 nozzles: a M5 and a M3 (M3 is going to be replaced by a M5 soon).
I included the image below to show the injection curves I'm currently using.
I would first like to know how the "Tune" button on the VariCool will affect the injection curves if I set it lower than 10. Is it going to reduce the whole curves by a percentage? If this is not the case, is there a way to reprogram it to do this? I'm a programmer myself and wouldn't fear to play with the VS firmware if I had access to it.
Do you have access to the 150 psi pump specification regarding pressure versus dutycycle? Am I right to think that if the pump runs at 50%, it will deliver approx. 75 psi? I have calculated my chart's injection start points based on that assumption and I would like to know if I'm right.
Here's the formula I came with to calculate minimum required dutycycle:
For example, if the MAP is 22psi, the checkvalve has a 22psi cracking pressure and the pump has a maximum pressure of 150 psi, I would need 29.33% dutycycle for the fluid to be able going through the line. What I'm missing now is the minimum pressure for good atomization. Having this, I could have a good injection start point. What is the minimum pressure I need to run with a dual-nozzle setup to obtain good atomization with the CoolingMist checkvalve and the 150 psi pump?
Thanks!
Drachonyx
p.s. : Would it be possible to hook the Varisafe to one of the injector ground and program it to inject based on injector dutycycle? Would it need any special hardware or one of the counter input would do?
p.s. 2: Are there any chances that the Varicool and the Varisafe are going to be included on the same board in a near future? IMO, that would be great to have a single injection control module without needing to hookup two devices together. Plus, it would be probably cheaper.
Ok, let me see how I can help. First your insane (thats a compliment). Each time you lower the tune button on classic vari-cool it will change the overall curve by 7.5%. so if you set the tune to 6 when you hit your max voltage you will be at 70%. It scales new curve over your entire range.
As far as getting access to the firmware, you are insane (not as much of a compliment)
Thanks!
Drachonyx
it varies based on nozzle size(s). To know, you should simply put a pressure gauge in line and run the vari-cool at various dutycycle. If you have V1.04 of the Classic Vari-cool software or later you can use the prime button. There is a box where you can put the dutycycle in. You can actually keep changing the numbers from 1 to 100 and see what the pressure is for each one.
We had done this in the past with the VS and you can get the injector dutycycle from 0 to about 85% pretty accurately, but after that it doesnt work so great so we never released it. To get the IPW is tricky because the pulse width is so short. We have the memory basically maxed out on that controller it cant read it correct. When we re-design the controller at some point this is one of many things we have planned.
we just designed 2 new controllers (VC2 and CMGS). we have alot of really cool things planned but I cant discuss them yet. The smart controller was the most complex thing we ever did. The software itself took us a year and a half. Its not something that we can just jump in and design there are so many things that must be considered including the small market for this device and the high cost/time of development.
I am really glad you are getting good use. Its hard for me to pick a favorite product that we have, but this is probably the one I am most proud of.
If I did not answer anything good enough let me know.
Ah, nevermind. If you say that one click of the button is 7.5% overall, that's exactly what I need.
Okay, I'll test the system. The good thing is that I already have a GM 130 psi fuel pressure sensor hooked to my W/I system, so I can already see the pressure, but it's really non-constant when under WOT: the readings are all over the place. I'll need to unhook the injectors and measure.
David
The Varisafe is pretty cool. It would need some more inputs though. 4 inputs is not enough.
I spent so much time working on my system I can't count the hours now. Every now and then, I find another way to do things and then hack into the wires and add stuff.
I just ordered a flow sensor through Kinetic so that my failsafe system can be complete. Now, I just need to find a way to hook up the VS so that it can drop the turbo toys' DAB setting to DAB 0 or 1 in case of problem. Not that much work and I won't need an external boost controller.
Thanks for the answers!
I will contact you this fall about the 2nd version of the Smart Controller to get some input from you as well as share what we have planned. Should be cool.
Another question about the Varisafe: when injecting based on the 8x8 grid, what happens when one of the inputs go past the X or Y-axis? For example, I set the X-axis with RPM from 2000 to 6500. If the RPM goes beyond 6500, does the Varisafe uses the last value for the cell @ 6500?
Can I order the dual nozzle setup for the HOM kit separately? I went to get an sct tune the other day and my tuner told me at 4500 rpms theres not enough meth and I keep getting booted out of HOM, making my numbers drop.
