Old 06-16-2009, 07:43 PM   #691 (permalink)
dcsax's Avatar
Member Number: 4232
Trader Rating: (13)
Quote: Originally Posted by Coolingmist View Post
That would be fun to do, all you need to do is find a wire that has either 12V or a ground when you press that button and i can help you with the rest. Just let me know.
david
Cool, I'll give you a call tomorrow.
Mods: Lots of stuff
dcsax is offline   Reply With Quote
Old 06-16-2009, 09:03 PM   #692 (permalink)
Member Number: 38712
I prefer on any application to do close to the ic exit if possible, but its not required.
Lastly, putting the nozzle on the bottom is a mistake, you will get sediment landing on the nozzle that will clog the orifice.
David
Thanks for the excellent information David!
So I'm guessing side of the pipe or top of the pipe is of little consequence then, I'll just look for a convenient location and get 'er in there!
Thad
Tjabo is offline   Reply With Quote
Old 06-17-2009, 04:44 PM   #693 (permalink)
EvilSRTMo's Avatar
Member Number: 49027
In An SRT-4, where should I connect the Red Power Wire in the fuse box? I wired it into one of my accessorie power sources after the fuse (so it is fuse protected at that end), but the 3 amp fuse that came with the kit keeps blowing, I also tried a 5 amp fuse and that blew also. So I am just curious where everyone else wires their kits. Thanks
GT3076R + 23 psi+ Methanol Injection. Numbers Coming Soon!!!
EvilSRTMo is offline   Reply With Quote
Old 06-17-2009, 04:46 PM   #694 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
Hi. Your kit came with a 7 amp fuse which will work fine. Unfortunately the fuse holders we bought were stuffed with a 3 amp (strange), we included a seperate 7 amp in the contents. If you lost it, just replace it with a 7 amp and you will be fine.
Old 06-18-2009, 05:22 AM   #695 (permalink)
EvilSRTMo's Avatar
thanks
Old 06-18-2009, 05:23 AM   #696 (permalink)
EvilSRTMo's Avatar
Oh and btw, do I have to run any lubricant through this system at anytime?
Old 06-18-2009, 07:06 AM   #697 (permalink)
Trader Rating: (64)
no, infact we advise against it.
Old 06-20-2009, 03:34 PM   #698 (permalink)
KAZ109's Avatar
Member Number: 25334
Trader Rating: (19)
Need to find a "Y" fitting so I can run both nozzles...I didnt find it on your website So I was wordering if I can run a Snowperformance "T" fitting with your kit???
C.O.B
A vision without a plan is just a hallucination
KAZ109 is online now   Reply With Quote
Old 06-20-2009, 06:02 PM   #699 (permalink)
Trader Rating: (64)
Here you go
Coolingmist Water Injection, alcohol injection and Methanol Injection systems
Old 06-21-2009, 12:55 AM   #700 (permalink)
KAZ109's Avatar
Trader Rating: (19)
Ordered thanks.......but can u ship to a different address??
Old 06-21-2009, 07:06 AM   #701 (permalink)
Trader Rating: (64)
Hi. it says on the order page to put what ever address you want it shipped it. Once you click "Submit" it prints the fedex label and sends you the tracking. Do you need to somewhere else?
Old 06-21-2009, 09:38 AM   #702 (permalink)
KAZ109's Avatar
Trader Rating: (19)
yes I need it shipped somewhere else
Old 06-21-2009, 09:59 AM   #703 (permalink)
Trader Rating: (64)
ok, send the new address to our email (reply to the email we sent you). Do this asap so we can fix this.
David
Old 06-21-2009, 07:25 PM   #704 (permalink)
KAZ109's Avatar
Trader Rating: (19)
David
Email sent!.......Thanks
Old 06-24-2009, 05:54 PM   #705 (permalink)
Member Number: 52407
Okay I have a question, I just got the kit and I've been marking the wires to what goes where. First question, what are these three wires for? The small black orange and yellow?
Next question, I have a button and an LED on my dash for an intercooler sprayer which I don't use. I want to wire my stage 2 VC2 kit so that it is only active when I push the IC sprayer button.
You said earlier that you could wire it to inject based on voltage and boost and wire the blue wire so it only gets voltage when I push the button thus activating the kit. However then I couldn't inject based on TPS voltage and boost, I would just be injecting based on boost, so is there any other way of accomplish this?
Ofcourse maybe injecting based on boost is all thats neccessary, perhaps you could help me decide.
7055 is offline   Reply With Quote
Page generated in 0.17684 seconds with 13 queries
