Old 06-02-2009, 07:41 AM   #646 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
Quote: Originally Posted by UT-05SRT-Neon View Post
This makes sense. But, is the 250 psi pump overkill for 300 hp? And how do you adjust when to turn the injection on without the progressive controller? Is there some in car thing which allows you to do this? I didn't see one in the contents of the trunkmount kits.
you can run the 150, it will be fine. without the progressive controller you will need a hex key and you turn the boost switch. Its not in the cabin, its under the hood. I PM you.
Old 06-02-2009, 08:06 AM   #647 (permalink)
Member Number: 69995
Thanks for the timely responses My only question is, how hard is it to use the progressive controller? Is it pretty user friendly or will it require a local tuner?
UT-05SRT-Neon is offline   Reply With Quote
Old 06-02-2009, 08:14 AM   #648 (permalink)
Trader Rating: (64)
its simple to install and use. no laptop is needed to configure it and it has alot of cool features like the ability to read your boost.
David
Old 06-02-2009, 08:20 AM   #649 (permalink)
I ordered my kit, with the help of David! Awesome customer service. I will be back with questions once I start the install!
Old 06-02-2009, 08:23 AM   #650 (permalink)
Trader Rating: (64)
always appreciated!
David
Old 06-03-2009, 10:38 PM   #651 (permalink)
Lilone123's Avatar
Member Number: 43600
I purchased a used standard trunkmount kit that I will be getting soon. The only nozzle he has for it is the M10 nozzle.
Will the M10 be too big for my setup? S3 with most bolt-ons, and will be tuned with a DSP.
S3 w/o, MPx 3" TBE, catch can/checkvalve, Walbro 255, MM inserts, AEM SRI, AGP fmic, Meth, DSP Tuned
Lilone123 is offline   Reply With Quote
Old 06-03-2009, 10:40 PM   #652 (permalink)
Chief's Avatar
Member Number: 61336
yeaa, its alot man, believe me, I got a 60-1 turbo, and its alot for it, once i get injectors im going back to M5, m10 SUCKS water, i go through a tank FAST.
Built bottom end
strapped BC and CP
HTA 60
PTP when you fedex man gettin this block?
Chief is offline   Reply With Quote
Old 06-04-2009, 07:32 AM   #653 (permalink)
Trader Rating: (64)
a M10 can be alot on our standard trunknount. For an S3 car you can you with the M8 500 CC on the Standard TM Kit.
CM
Old 06-07-2009, 04:35 AM   #654 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
sure, instructions are here: Follow the diagram for cool150. its very simple.
http://www.coolingmist.com/instructi...structions.pdf
any questions let me know.
I recently purchase the CM150 kit. I ordered mine off ebay and included i'm around 300whp, would this mean I would've gotten the M5 nozzle?
or 16 whatev
WTB: LCA bushings
Old 06-07-2009, 07:05 AM   #655 (permalink)
Trader Rating: (64)
yes, 380 cc, M5. thats the correct nozzle.
Old 06-09-2009, 10:27 AM   #656 (permalink)
StiEater04's Avatar
Member Number: 70403
how do i know which one is mine lol i clicked on instructions but i still have no clue which is mine its a dual nozzle trunk mount kit thats literally all i was told
FWD FTW
StiEater04 is offline   Reply With Quote
Old 06-09-2009, 04:05 PM   #657 (permalink)
Lilone123's Avatar
I ordered a nozzle and recieved it today. I am wondering about the filter on the inside. Is the filter supposed to be screwed in and snug? It is a bit loose when I recieved it. I'm assuming it is supposed to be snug, but just checking.
Old 06-09-2009, 07:14 PM   #658 (permalink)
Trader Rating: (64)
filter should be tight. just remove the nozzle and tighten it. Sorry about that!
CM
Old 06-11-2009, 12:24 PM   #659 (permalink)
StiEater04's Avatar
bump far an answer please thanks
Old 06-11-2009, 01:01 PM   #660 (permalink)
Trader Rating: (64)
if you have a boost switch click on the standard kit instructions.
If you have a vari-cool click on the vari-cool instructions.
Thanks!
Page generated in 0.17420 seconds with 13 queries
