Old 12-06-2006, 07:12 PM   #46 (permalink)
cali's Avatar
Member Number: 159
Quote: Originally Posted by Grifter
Quote: Originally Posted by cali
You know...sometimes I wonder why I even bother attempting to educate you people....
I took what you said and looked at the links. Thanks. We all know you hate Coolingmist...
Actually I dont hate CM...Its the stupidity that gets under my skin.
Any my car has a CM part in it...sad to say aint it?
I was just trying to help you...you asked a question..several times. And he was adamant with his answer....I simply put up a couple links to a thread where people besides ME have run the experiment.
After all....I just go out of my way to pick on CM...right?
someone is watching me
Old 12-06-2006, 07:18 PM   #47 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
You dont have a coolingmist kit. I dont care what experiments you do or anyone else did, it wasn't our product and its not valid to me. Our kits operate as I say they do. Everything I said is 100% fact.
This is why we can have 15 feet of hose after checkvalve on our trunk mount kit and it will inject INSTANTLY from the time the pump gets power (after the first time the tank is full and you pressurize the line) and it shuts off within a split second with Virtually NO leakage. But you will contest that too I am sure.
If you cant see that, I cant help you.
Old 12-06-2006, 07:34 PM   #48 (permalink)
Member Number: 17858
I wasn't be sarcastic, I really did take your info and read it, and I did mean it when I said thanks for the info. But it's painfully obvious, whether CM "started" this whole controversy or not, that you came in here to pick a fight. You knew David would take the bait, if you didn't want a conflict you should have posted the links and nothing else.
Back to the topic please.
Grifter is offline   Reply With Quote
Old 12-06-2006, 09:55 PM   #49 (permalink)
Trader Rating: (64)
Quote: Originally Posted by JohnL
Just installed my new CoolingMist nozle that screws directly into a threaded hole(in my cold side pipe), also have the 90 deg fitting with the new quik-release hose fitting on it.
All I can say, is the new hose fitting is "MONEY!!!" , so simple and so easy to remove.
Thanks again CoolingMist
John,
Thanks alot for your support. I am glad you like our new fittings and design. We will never compromise on quality. No plastic clips or nylon composite body on any of our fittings.
Thanks again and let us know if we can help further.
Old 02-11-2007, 12:08 PM   #50 (permalink)
Trader Rating: (64)
bump!
Old 02-11-2007, 01:41 PM   #51 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (31)
I currently have the coolingmist Srt trunk mount kit with 150psi pump. I'm going to be pushing around 500whp for now. I currently have a m5 injector, do I need a bigger one? I bought the kit when I was around 450whp. I might end up going over 500whp once I get the car tuned out. Thanks!
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon...
7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
Old 02-11-2007, 01:44 PM   #52 (permalink)
Trader Rating: (64)
If you go just above 500 HP you may want to get our 7-8 GPH nozzle. If you are 450 or under you are on the border but probably ok at 6 GPH.
Old 02-11-2007, 01:51 PM   #53 (permalink)
Trader Rating: (64)
I need to update this thread. These quotes are all in this thread. I stated that our system would shut off near instantly when the power is turned off and the system would spray near instantly once the power is turned back on. I was clear that would be no delay. Certain people on this forum (below) love to attack everything I have to say. I just want to post video for proof.
Quote: Originally Posted by coolingmist
if the valve is closed and there is water in the line and the valve does not come open, water cant seep out. Do the experiment I told you, think of your thumb as the checkvalve and the other side the hose that connects to the checkvalve.
Or you can just trust me.
CM you are 100% wrong wrong wrong!
CM,
How can you sell WI kits and spew mis-information?
Grifter, I encourage you to perform the expermient.
Here is the video. Make your own decisions. Also I would point out that this is how our current group of kits perform. Other kits on the market may or may not have a long delay and cause this problem. Ours does not:
Here is a video below. Here is the setup:
http://coolingmist.com/info.aspx?key=newvid
16 GPH nozzle
15 feet of hose from tank to sink
checkvalve at the pump
I am not able to take a video from a distance from the tank so I hooked up an LED to show you when it gets power and activates.
Pic of the checkvalve/tank.
Nozzle size
Here is the setup, sorry its not pretty I did not have much time today.
Old 02-11-2007, 02:20 PM   #54 (permalink)
turbo666's Avatar
Trader Rating: (31)
Well I don't always plan to run 28-30psi on my 60trim, I will have a pump gas tune. Will it be ok to run the 7-8 GPH nozzle at less then 500whp?
Old 02-11-2007, 02:46 PM   #55 (permalink)
Trader Rating: (64)
I personally dont think you will have any problems running 7 GPH if you are close to 500 HP. If you have 300 HP you would have too much flow for sure.
If you want to try a larger nozzle let me know. If it doesn't work for you I will refund your money.
David
Old 02-17-2007, 07:09 PM   #56 (permalink)
EricP's Avatar
Member Number: 22154
I can vouche for coolingmist's trunk mount kit stopping the water flow pretty much instantly. When I stopped by their shop to pick up my kit he demonstrated the whole thing to me and showed me how fast the water stops spraying
Stock Turbo
WHP:283 WTQ:334
EricP is offline   Reply With Quote
Old 02-18-2007, 02:18 PM   #57 (permalink)
cp980fps's Avatar
Member Number: 12921
Oh Cali .... Once again you are full of shit !!! I ran a line from my check valve under the hood , all the way up inside the cabin of the car, to a M3 nozzle on the end.
I just HAD to know how my system was reacting , so I played the Guinea Pig and held that nozzle righ in front of my face , spraying towards the open side window.
Here's what I found out :
The INSTANT the W/I light kicks on at 1 lb of boost , the water starts spraying instantly. The INSTANT the light goes out signaling the pump has stopped .... The water stops spraying instantly.
When you are going down the road at 50 mph with your window open , the water DOES hit you right in the face ...
I did the test , and it works as advertised.
cp980fps is offline   Reply With Quote
Old 02-19-2007, 04:17 PM   #58 (permalink)
Trader Rating: (64)
Here is a picture of our latest kit. We have had so many orders for this kit on this forum that we decided to make it a regular product on our site. Vari-Cool Direct Port Trunkmount kit.
http://www.coolingmist.com/detailmai...pid=Directport
The direct port kit will ship with our high gloss nickel plated low-profile fittings. These fittings will fit flush for a completely integrated look. Turn by hand and then just takes 1/2 turn with a wrench to lock in place. No tefon tape is required, it has an oring to seal against any leak. You can see the fittings on our checkvalve and pump to get an idea of how low profile they are. These are show quality, not just nickel plated but highly polished.
Old 02-19-2007, 04:27 PM   #59 (permalink)
EricP's Avatar
looks like a sick kit!
Old 02-19-2007, 06:33 PM   #60 (permalink)
bryan9097's Avatar
Member Number: 48384
Trader Rating: (19)
I can also vouch for CM, this kit works as David says.
AGP S3 Delta 44, Walbro 255, S2 WO Toys, PTP CV,3" exhaust depot, PTP HS, Greddy TT, AGP dog bones & Trans mount, 18" Sports Max Racing rims, Mopar Performance Clutch, Mopar BOV, Mopar SS, Mopar CAI, Mopar oil pressure gauge, Mopar Volt Gauge, cooling mist W/I (trunk mount)using Cool fuel, BWoody CC, CBD B&C Pillars, CBD fog lights inserts, BFG 225/40/18, Magnaflow 3 in/out muffler, Eibach sportline springs, AEM UEGO, Darksyde ported intake & TB.
bryan9097 is offline   Reply With Quote
« stock intercooler | - »
Page generated in 0.19031 seconds with 13 queries
