Old 12-06-2006, 09:51 AM   #31 (permalink)
Member Number: 17858
Quote: Originally Posted by Coolingmist
It will not be completely empty. Once the pressure drops below 22 psi, on the valve the system will stop spraying. There will definately be water in the line.
Oh, I would think that once engine vacuum sucks in through the nozzle(s) it would empty out the line.
Thanks dude.
Grifter is offline   Reply With Quote
Old 12-06-2006, 10:00 AM   #32 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
take a straw and dip it in water. Take your thumb and put it over the other end of the straw and see if the water falls out.
vacuum cant open the valve, the water cant come out. this is why our new trunk mount kits can have 15 feet of hose after the checkvalve and stop spraying with in a split second and start spraying instantly. water stays in the line.
Thanks dude.
Old 12-06-2006, 10:36 AM   #33 (permalink)
But I am referring to the line after the CV, that goes to the nozzles? How does the CV prevent that from getting sucked in?
Old 12-06-2006, 10:39 AM   #34 (permalink)
Trader Rating: (64)
So am I. if the valve is closed and there is water in the line and the valve does not come open, water cant seep out. Do the experiment I told you, think of your thumb as the checkvalve and the other side the hose that connects to the checkvalve.
Or you can just trust me.
Old 12-06-2006, 11:20 AM   #35 (permalink)
Haha, I trust you. I was having a hard time visualizing it.
Thanks.
Old 12-06-2006, 11:21 AM   #36 (permalink)
cali's Avatar
Member Number: 159
CM you are 100% wrong wrong wrong!
someone is watching me
Old 12-06-2006, 11:22 AM   #37 (permalink)
Trader Rating: (64)
I understand, I am not explaining it too well, sorry.
Old 12-06-2006, 11:27 AM   #38 (permalink)
JohnL's Avatar
Member Number: 2265
Just installed my new CoolingMist nozle that screws directly into a threaded hole(in my cold side pipe), also have the 90 deg fitting with the new quik-release hose fitting on it.
All I can say, is the new hose fitting is "MONEY!!!" , so simple and so easy to remove.
Thanks again CoolingMist
2009 Alpine White BMW 135i.- 12.8 at 112mph with a 2.187 60ft
JohnL is offline   Reply With Quote
Old 12-06-2006, 11:30 AM   #39 (permalink)
cali's Avatar
Member Number: 159
WI and SRT's - My observations - Good Read
CM,
How can you sell WI kits and spew mis-information?
Grifter, I encourage you to perform the expermient.
Old 12-06-2006, 11:47 AM   #40 (permalink)
Trader Rating: (64)
Grifter,
We test all of our products, I stand by what I said. Feel free to do what ever testing you want.
David
Old 12-06-2006, 02:23 PM   #41 (permalink)
It was just a question, I was curious so I asked it. I don't notice any lag or anything.
Thanks again David.
Old 12-06-2006, 02:25 PM   #42 (permalink)
Trader Rating: (64)
Thanks again David.
You are more than welcome to ask any questions you want. I made that last statement because of a previous posters ignorance and innapropriate comments.
David
Old 12-06-2006, 05:52 PM   #43 (permalink)
David
I was kind of referring that post to him...
Old 12-06-2006, 06:59 PM   #44 (permalink)
cali's Avatar
Member Number: 159
You know...sometimes I wonder why I even bother attempting to educate you people....
Old 12-06-2006, 07:05 PM   #45 (permalink)
I took what you said and looked at the links. Thanks. We all know you hate Coolingmist...
« Meth mix help | - »
Page generated in 0.15330 seconds with 13 queries
