Old 12-28-2007, 06:57 AM   #406 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (68)
Quote: Originally Posted by pumpkin05 View Post
I have your kit and was wondering if changing the stock coldside is a must? The shop I took it to told me that if installed the hose/nozzle will keep blowing off. Is this true and is it worth me getting installed on the stock pipe? Thanks.
Our hose will not pop off our fittings unless there is a defect or it is installed wrong.
Where do you have the nozzle installed now?
David
Old 12-28-2007, 08:17 AM   #407 (permalink)
pumpkin05's Avatar
Member Number: 54667
David
It isn't installed. I've been waiting to get an aftermarket coldside pipe like I was told. But I knew you guys are on the site and figured I'd ask you. Where should I have the nozzle installed? Also would a snowperformance unit work with my basic coolingmist kit?
Rage-Tuned need I say more
pumpkin05 is offline   Reply With Quote
Old 12-28-2007, 05:40 PM   #408 (permalink)
Trader Rating: (68)
I would not buy anything from Snow Performance if I were you. You would be better off running without a system rather than use something from them.
Having said that, you should install the nozzle in the cold side pipe. its a 1/8th NPT fitting, so it needs drilled and tapped.
Let me know if you have more questions and happy new year.
David
Old 12-28-2007, 11:22 PM   #409 (permalink)
pumpkin05's Avatar
David
Thanks for the help. You guys are great! No one compares to your service on here. Happy new years!
Old 12-29-2007, 11:47 AM   #410 (permalink)
coparthn's Avatar
Member Number: 24529
We have many stock SRT-4s with our kits. Typically HP gains are 18-20 WHP. Boost can typically be raised by a few lbs, it varies from car to car.
Let me know if I can help more.
David
thanks david gain 18 -20 whp how many psi i need boost ?
how many psi i can boost with alcky on stock turbo
coparthn is offline   Reply With Quote
Old 12-29-2007, 01:12 PM   #411 (permalink)
Trader Rating: (68)
amount of more boost that you can run varies. 2-3 is tyical.
David
Old 12-29-2007, 06:18 PM   #412 (permalink)
coparthn's Avatar
my car spike 15s holind 13s can i spike 19s holding 16-17s? with alcky?
Old 12-29-2007, 07:50 PM   #413 (permalink)
Trader Rating: (68)
our kits will cool your charge temps and intake temps allowing for more boost. i cant promise how much, but its the best bang for the buck.
David
Old 12-29-2007, 10:50 PM   #414 (permalink)
SRT of the Month
Darksyde's Avatar
Member Number: 37254
Trader Rating: (211)
Which is a better .5v source the tps or the map for the controller? Would the map be off alittle if using a FC?
500 WHP Club
Darksyde is offline   Reply With Quote
Old 12-30-2007, 05:58 AM   #415 (permalink)
CantStopSpinin's Avatar
Member Number: 56380
Darksyde i love your Signature btw. lol
mopar stage 3 FTW!
current cars:
05 white srt-4...stage 3 full bolt ons
04 blue srt-4....s256 + full bolt ons
98 contour se sport
CantStopSpinin is offline   Reply With Quote
Old 12-30-2007, 07:12 AM   #416 (permalink)
Trader Rating: (68)
Our controller can read boost directly. Just hook up your boost line. If you do it that way, the knobs on the controller will be calibrated for boost. We have our own map sensor built in.
Of course you can still use TPS as well. Our stage 3 HOM kits use both TPS and BOOST.
CM
Old 12-30-2007, 12:41 PM   #417 (permalink)
SRT of the Month
Darksyde's Avatar
CM
I have the stage 3 hom kit so
tps sensor it is.
If anybody else could answer which wires are the .5v input and .5v Ground on the tps?
Thanks
Old 01-02-2008, 06:29 PM   #418 (permalink)
daniel427ss's Avatar
Member Number: 51325
i installed my injector after the IAT sensor, can i add a lower GPH injector before the sensor just so that the sensor can detect the colder temps going in.
what i want to know is if it is as simple a T-ing off on the line or should i say Y-ing off the line to have 2 injectors????
edit: i currently have something around the 9gph, (i was never told wut exactly was by u guys), i asked for something around the 400+HP though.
daniel427ss is offline   Reply With Quote
Old 01-02-2008, 06:38 PM   #419 (permalink)
Trader Rating: (68)
Daniel, what kit do you have?
If you have 9 GPH, adding a 1.3 GPH may or may not be too much. It is a simple matter of using a T.
David
Old 01-02-2008, 07:37 PM   #420 (permalink)
Trader Rating: (68)
another option, we have .7 GPH injectors rather than the 1.3 GPH, that may be an option.
