Old 09-09-2007, 03:53 PM   #301 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
The only way to know is to hook up an LED to it, otherwise you are just guessing.
David
Old 09-09-2007, 05:20 PM   #302 (permalink)
Member Number: 47374
Last question. Im about to put the distilled water in to test it. Wont hurt to put the washer fluid in after testing even if there is a small amount of distilled water still in there will it??
258whp/287wtq
Stage 1 / Mopar 1" lowering springs / AEM SRI / Poly engine mount inserts / Ported Turbo, Manifold, Throttle Body / AGP Billet Wastegate / 80% Reduction STS
OMG SRT4 is offline   Reply With Quote
Old 09-09-2007, 05:41 PM   #303 (permalink)
Trader Rating: (64)
The distilled water will not hurt your system at all. You can run water, methanol or denatured alcohol or a combo of those. I cant guarantee that WWF will or will not damage anything.
David
Old 09-09-2007, 06:44 PM   #304 (permalink)
k maybe not last question. 1 i cant figure out if its even coming on, and 2 i cant figure out which solenoid i should hook it up too. I have two open ones and the first try the pump never came on, 2nd solenoid my car hit like 10 psi and felt liek it just shut down and i smelt something bad.
Do you or anyone else know which solenoid i should put it on
Old 09-09-2007, 06:52 PM   #305 (permalink)
Trader Rating: (64)
your kit does not come with a solenoid. Please find your kit in our instructions page. You will find detailed installation pictures on this PDF. It should answer all of your questions.
http://www.coolingmist.com/info.aspx?key=installdocs
Old 09-09-2007, 07:01 PM   #306 (permalink)
I mean in all the vacuum lines my bad.. Your instructions to not say i've read them 10000 times while installing. The line that reads the boost needs to connect somewhere into one of my vacuum lines.... I cant figure out which one to connect it to so it knows when i read 10psi...
Your instructions just say to a vacuum source.... i tried my two open ports and got nothing so im assuming its not reading my boost
Old 09-09-2007, 07:03 PM   #307 (permalink)
Trader Rating: (64)
connect it to the same line your boost gauge is connected to.
Hope that helps.
CM.
Old 09-09-2007, 07:04 PM   #308 (permalink)
Anyone know which one that is?
Thats what i was trying to figure out but cant find a decent diagram
Old 09-09-2007, 07:10 PM   #309 (permalink)
Trader Rating: (64)
I dont have a specific picture, hopefully someone will chime in.
C M
Old 09-09-2007, 08:33 PM   #310 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (65)
since coolingmist has helped me out in a great deal.. I'll return the favor..
what I use for boost source...
http://www.SRTCanada.com <----- alternate site for canadians.
DiabloSport Trinity Beta Tester
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 09-09-2007, 09:19 PM   #311 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
If you didn't want to tap into one of the lines coming off the TB then you could use one off of the brake booster....that is where the stock boost gauge gets it's pressure source from!
RoostBoost is offline   Reply With Quote
Old 09-09-2007, 09:44 PM   #312 (permalink)
i tapped in just like his pictures with a Y connector. Buddy sat in the back and said he heard the pump come on.... but i feel no difference at all
I guess its spraying but no noticeable power
Old 09-10-2007, 06:51 AM   #313 (permalink)
bryan9097's Avatar
Member Number: 48384
Trader Rating: (19)
I have to be honest. I never felt noticeable power difference, just studdoring. I reckon you have to tune to get benefits. My S2 does not like it at all.
AGP S3 Delta 44, Walbro 255, S2 WO Toys, PTP CV,3" exhaust depot, PTP HS, Greddy TT, AGP dog bones & Trans mount, 18" Sports Max Racing rims, Mopar Performance Clutch, Mopar BOV, Mopar SS, Mopar CAI, Mopar oil pressure gauge, Mopar Volt Gauge, cooling mist W/I (trunk mount)using Cool fuel, BWoody CC, CBD B&C Pillars, CBD fog lights inserts, BFG 225/40/18, Magnaflow 3 in/out muffler, Eibach sportline springs, AEM UEGO, Darksyde ported intake & TB.
bryan9097 is offline   Reply With Quote
Old 09-10-2007, 09:22 AM   #314 (permalink)
daniel427ss's Avatar
Member Number: 51325
did u do a 50/50 mix of water plus methanol(Heet) n maybe added 5psi of boost???
If so, there was supposed to be noticeable POWA
daniel427ss is offline   Reply With Quote
Old 09-10-2007, 09:36 AM   #315 (permalink)
I'll have to try that today and see. I was just using washer fluid with the same boost.
Page generated in 0.17978 seconds with 13 queries
