Old 08-07-2007, 05:08 PM   #241 (permalink)
bryan9097's Avatar
Member Number: 48384
Trader Rating: (19)
Question Nozzle clog
I have the M3 nozzle and it seems that I am pulling the thing out constantly to unclog the nozzle. Is this common for the M3? Also what would you suggest our spark plug gap be using Denso Iridiums, with M3 and M5 nozzles?
AGP S3 Delta 44, Walbro 255, S2 WO Toys, PTP CV,3" exhaust depot, PTP HS, Greddy TT, AGP dog bones & Trans mount, 18" Sports Max Racing rims, Mopar Performance Clutch, Mopar BOV, Mopar SS, Mopar CAI, Mopar oil pressure gauge, Mopar Volt Gauge, cooling mist W/I (trunk mount)using Cool fuel, BWoody CC, CBD B&C Pillars, CBD fog lights inserts, BFG 225/40/18, Magnaflow 3 in/out muffler, Eibach sportline springs, AEM UEGO, Darksyde ported intake & TB.
bryan9097 is offline   Reply With Quote
Old 08-07-2007, 05:42 PM   #242 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
does it clog from the inside or outside? Use filtered water if its clogging from the inside. If its clogging from the outside, that means you are getting alot of debris past your air filter. The smaller nozzles will clog easier than the large ones, but something still sounds wrong as it should not clog so fast...unless you water is dirty.
About spark plug gap, frankly I have absolutely no data on that. Maybe someone else can jump in?
Old 08-07-2007, 06:05 PM   #243 (permalink)
Member Number: 38084
subscribed
skatevans450 is offline   Reply With Quote
Old 08-07-2007, 06:20 PM   #244 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
as far as gap goes you should lower the gap depending on how boost you are running...W/I shouldn't affect the spark as it pretty much evaporates by the time it reaches the combustion chamber.
I'm not sure why your nozzles are clogging so often as that just shouldn't happen unless you are using mineral or spring water. Distilled water would be the best or even filtering the distilled water for even "cleaner" water
RoostBoost is offline   Reply With Quote
Old 08-08-2007, 03:43 PM   #245 (permalink)
bryan9097's Avatar
Trader Rating: (19)
Actually, I have benn using spring water. I ASSumed that it would be filtered. Where in the sam hill can I get DISTILLED water?
Old 08-08-2007, 04:04 PM   #246 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
you can get distilled water in 1gal. plastic containers at the supermarket, or maybe even Target, Kmart, Walmart, etc...
Old 08-08-2007, 07:14 PM   #247 (permalink)
bryan9097's Avatar
Trader Rating: (19)
Okay, so you can by it at the same place as SPRING water, but isn't spring suppose to be filtered water as well? I must admit this is news to me.
Old 08-08-2007, 09:39 PM   #248 (permalink)
if im purchasing a basic kit, does it come with a led to let me know when im spraying. if not than where can i pick one up.
thanks
Old 08-08-2007, 09:40 PM   #249 (permalink)
Trader Rating: (64)
Hi, none of our kits come with a LED, but you can get one at radioshack or pepboys.
CM
Old 08-09-2007, 07:44 AM   #250 (permalink)
Member Number: 8193
thanks
Get the LED with the built in 1/4W, 680 ohm resistor. In the aplication your going to use it ones without will just make smoke or blow fuses.
This page intentionaly left blank
Old 08-14-2007, 05:22 PM   #251 (permalink)
im having trouble on finding the ignition wire on my car. can someone tell me or post a pic of it.
thanks
edit: nevermind figured it out
Old 08-15-2007, 01:44 AM   #252 (permalink)
i have the deluxe 150 kit and im a little confused about the led for spraying. do i wire it in between the 85 on the relay and the NO port on the boost switch? or between the pump and relay or somewhere else?
Old 08-15-2007, 07:34 AM   #253 (permalink)
Trader Rating: (64)
Give one end of the LED 12V, hook the other to the 85 PIN of the relay.
CM
Old 08-15-2007, 01:45 PM   #254 (permalink)
okay so which vacume line should i use to tee off into the boost switch?
Old 08-15-2007, 05:52 PM   #255 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
use a line off of the TB
Page generated in 0.17224 seconds with 13 queries
