Old 06-09-2007, 10:38 PM   #181 (permalink)
goats srt's Avatar
Member Number: 47689
ok sounds good i dont have the wire dia. on me right now but i dont think its a big deal to do anyways what nozzle size do think i should use to be able to hold HOM with my list of mods
look in my for sale thread
selling good stuff check it out
goats srt is online now   Reply With Quote
Old 06-10-2007, 10:31 AM   #182 (permalink)
parsonsproject's Avatar
Member Number: 14704
Quote: Originally Posted by Stealth RT
Quote: Originally Posted by parsonsproject
Quote: Originally Posted by Coolingmist
It needs to be a 12V LED because your vehicle uses a 12V system.
CM
Ok thx I'll get a different LED. I remember getting a green and red LED, and that they had different ratings, I think the green one that keeps blowing the fuse is not a 12V.
Hey just to add 2 cents on the LED topic.
Don't just use a any old boxed 12V LED. Make sure it has a resistor built in. A LED is a Diode. It can be a short to ground.
This one will work
Or this one
This one would burn up or blow your fuse
So would this one
Thanks stealth, that's good to know, I will be picking up another LED tomorrow from the shack.
A "complete system" should have come with the LEDs and boost hose, IMO.
<-- 2007 coSRToc dyno competition winner, stock turbo class [298whp/344wtq] on 91 pump, 50/50 w/m, untuned stg1-->
(DS Trinity tuned, new #'s and win to come)
parsonsproject is offline   Reply With Quote
Old 06-10-2007, 11:03 AM   #183 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
When we supply led, someone will want green, another wants blue, another wants red, another wants orange,etc.
We supply the kit, the connect to the kit is up to the customer. I dont want to raise my prices.
CM.
CM
This one will work
Or this one
So would this one
Old 06-10-2007, 01:38 PM   #184 (permalink)
Member Number: 48372
This may sound noob or what not but I just had a quick question. If your going to get S3 W/ Toys would this replace the sprayer or would you even need the sprayer. I mean if W/I is better than the sprayer I wont even bother to get toys.
Then its S3 w/o toys + N2MB toybox + Cooling mist w/i.... ftw?
Thats only if the w/i does the same thing as the sprayer and stuff.
Thanks
-Mykel
MnM'SRT4 is offline   Reply With Quote
Old 06-10-2007, 06:31 PM   #185 (permalink)
Trader Rating: (64)
Thanks
-Mykel
what is a sprayer? you mean IC sprayer? save your money and go with CM.. It will own the "sprayer" Any day of the week.
CM
Old 06-10-2007, 08:37 PM   #186 (permalink)
Thanks
-Mykel
CM
Yah the IC sprayer is exactly what I was referring to. So do they do the same thing except the CM one is just x10000 better?
Old 06-10-2007, 08:44 PM   #187 (permalink)
Trader Rating: (64)
Thanks
-Mykel
CM
No an IC sprayer is a waste of money. The coolingmist injection sprays inside the intake, its far more efficient.
CM
Old 06-11-2007, 09:39 AM   #188 (permalink)
pumpkin05's Avatar
Member Number: 54667
I just ordered your kit and i was wondering what is the best way to tune it? Meaning what type of extras would i need?
pumpkin05 is offline   Reply With Quote
Old 06-11-2007, 10:29 AM   #189 (permalink)
Trader Rating: (64)
Im not sure what kit, if its our standard kit, its set to come on at 10 psi,`during driving if you get hesitation turn the dial higher. Ideal, you want the system to come on low enough to have great benefit (power gain) but not so high that you get hesitation.
if you have our controller kit you have our min/max/tune dial to play with.
CM
Old 06-12-2007, 07:40 PM   #190 (permalink)
pumpkin05's Avatar
Default water/meth tuning!!!
I have your standard kit and so far my car is stage 2, with a downpipe. Im all about getting everything i can from my performance parts so how would i pull everything from this kit? I plan on getting an apexi afc and was wondering if it will pull more power from the kit when the car gets tuned? And how much horsepower should i be expecting with it just being installed?
Old 06-12-2007, 07:45 PM   #191 (permalink)
Trader Rating: (64)
typically 15-18 HP just from bolt on is a good guess. You want the kit to come on as low as possible with out hesitation. Typically starting it around 12-13 psi and working your way from there. If you get hesitiation raise the level, if you dont you can lower it a little.
CM.
Old 06-13-2007, 07:09 PM   #192 (permalink)
Member Number: 52686
I plan on doing really only road course, autocross racing and plan on going with stage 3. currently everything is stock but i plan on throwing a few mods on my car to up the boost but heres my question. When im not at the track i work and goto school and basicly live out of my car and really try to get the best gas mileage i can. I barely hit boost going to and from school and work but will get on it some times and was wondering if getting a cm system would be worth the money and why. Because when i goto the track i put race gas in it and when im not at thr track for the most part i baby my car. Also i dont really like the idea of putting any water in my car and would like to run 100% meth which system would be good for that?
Come play with us
bloodbrother is offline   Reply With Quote
Old 06-13-2007, 07:15 PM   #193 (permalink)
Trader Rating: (64)
Thanks for the question. All of our systems can run 100% meth if you choose too. That means all components are chemically compatible. If your running race gas now, you will appreciate our kit as you can run 93 octain and skip the race gas. All of our kits will work with your system, it sounds to me you may be interested in our Standard trunkmount. Remember all of our kits can be upgraded to our controller, that is the great benefit our kits. Easy upgrade path. While our controller kits rock, with your usage I think the standard TM will suite you best. Please ask more questions if I have not elaborated enough.
CM
Old 06-13-2007, 08:19 PM   #194 (permalink)
^^^ Thanks that was just the type of input i wanted to hear. Just kind of planning for the future but right now my clutch is about the go and im going to make a weekend out of the install. But then im going to start getting into the go fast mods need something to hold me over till i get the s3 so you TM kit will be one of the next things on my list after clutch, sways, and strut bars
Old 06-14-2007, 02:25 AM   #195 (permalink)
RiVal's Avatar
Member Number: 51024
Sweet just read very Post here. Seriously I was totaly against W/I but after I got my Scan guage and seen All the Freakin Kr I got, W/I sounds sooo Sweet!
Yes I got questions.
1] the kit fer 169.99 should be plenty for my setup??? Mods in Sig should be 28Ohp-3OOhp
2] its boost activated. Does the system Spray just as Much from 1Opsi to lets say 22psi or will it change pressure?? Reason for asking is with stock turbo we drop off to 15psi. Not shur what I'm gettin @ but do u see whut I'm sayin?
Why doesn't the 199kit come witha selnoid CV??
-SMOKE-EM-UP- Eatin V8's spit on 6's and sh**in on any other
**OLD ET(2008): 12.715 @ 110.686 2.038 60ft
91/meth Street tires**
best Trap- 111.3
best 60ft- 1.972 street tires
**E85 NUMBERS coming SOON**
RiVal is offline   Reply With Quote
« stock intercooler | - »
Page generated in 0.18898 seconds with 13 queries
