Old 11-25-2008, 05:05 PM   #1 (permalink)
Member Number: 19079
Default Coolingmist installation help. Im stuck!
Alright my car had the kit installed (standard 150 psi kit)and one day it stopped working spraying at wot.... checked everything and everything was fine...tested it and it sprayed. odd.. so i decided to get a new boost switch relay and pump... i installed it and tested it and it sprays.... (i put the normally open wire to the not used port and it sprays... so i put it back to the normally open wire and connect the nozzle to the cold pipe and take it for a spin several times and no meth......IM 100% sure it doesnt spray since my afr stay the same.
what else can i check for? obviously the fuse is good and the pump works... im 97.5 percent sure the wiring is correct... any ideas?
CANIBUS115 is offline   Reply With Quote
Old 11-25-2008, 09:43 PM   #2 (permalink)
Mana4real's Avatar
Member Number: 25021
I had this problem. What youneed to do is check all of your vacuum lines connected to your boost source. I had one of my elbows split really bad. So bad that I could hear it while I was driving. The leak was so bad that no pressure was going to the switch so never activating the system. Trust me, look really close. Check all your lines and ZIP TIE THEM!!! Zip ties saved me a lot of trouble.
-Matt- -SCT Tuned- By Yours Truely
Page generated in 0.14871 seconds with 13 queries
