CM boost pressure switch not working & IC Sprayer Algorithm Question!
I just installed a meth kit on my car yesterday. It's the basic kit, but has the upgraded solenoid rather than a check valve. It was bought used off a forum member. I have the kit tapped into my washer fluid reservoir. When I tested the boost pressure switch, it worked fine and when it was installed it won't work. I screwed the allen screw all the way out (least pressure to engage) and have the wires on "COM" and "NO3" per the instructions. I pulled the hose off the tee into my boost line and blew as hard as I coud into the hose and it didn't kick on. I wanted to try the kit out, so tapped the signal wire into my IC sprayer line and am using the IC sprayer button to turn it on manually. Has anyone done this permanently using the algorithm mode on their IC sprayer? It seems to spray "most of the time" when in WOT. What inputs does the algorithm use to determine when too spray? I know the pump is working because the car will hold HOM when spraying but won't without the meth!
Thanks!!
04 E-Blue SRT-4, Mopar Stage 3R w/ Toys, JM Ported Head, AGP Mini FMIC, LFS TB, Needswings 3" O2, Catless DP, Mopar/Borla Exhaust, AEM UEGO, DSP Predator, CM Meth kit...........
