Old 10-29-2009, 05:58 PM   #1 (permalink)
Member Number: 37284
Default Boost switch
I just have the basic Coolingmist kit.
I have replaced the boost switch once before, and I believe its out again.
I switch the wires, so it runs anytime, and the pump runs. I put it back to how it should be, and I go make some runs, and my tank hasnt moved levels.
So I believe the switch is bad once again. What kind of suggestions do I have for this? Just get a 3rd switch? Or what are other people running.
I just use the meth to keep knock down.
SRT4chris2005 is offline   Reply With Quote
Old 10-29-2009, 06:08 PM   #2 (permalink)
RiVal's Avatar
Member Number: 51024
Id run a led light to inside ur cabin to see when/if its workin.. Also ull be able to tell @ what psi its kickin on.
-SMOKE-EM-UP- Eatin V8's spit on 6's and sh**in on any other
**OLD ET(2008): 12.715 @ 110.686 2.038 60ft
91/meth Street tires**
best Trap- 111.3
best 60ft- 1.972 street tires
**E85 NUMBERS coming SOON**
RiVal is offline   Reply With Quote
Old 10-29-2009, 06:16 PM   #3 (permalink)
Well, I know for a fact its not running when its wired up how it should be.
So any other solutions for it to be fixed? Just get another switch from their site? Or anything better?
Old 10-29-2009, 06:17 PM   #4 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
is it getting wet? did you check the hose going to the switch? remove the switch and blow air into it, do you hear a whistling sound?
boost switches are a simple mechanical switch. They are not the most robust part out there. They are meant to be inexpensive and replaceable. Having said that, we have had customers running them for years without issue.
If you really want to test it, remove the boost switch and put air to it with a hand pump. do you hear a click? If you hear a click your boost switch is fine. If you dont, its likely bad.
CM
Old 10-29-2009, 07:24 PM   #5 (permalink)
It may have been getting wet, I had it sitting behide passeger side headlight. Since then, I have moved it behide my JMB tranny cover.
Ill probably just end up buying a new one, since they are somewhat inexpensive, and keep it behide the cover. Im sure it was getting wet there.
Old 10-30-2009, 01:41 PM   #6 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Hmmm so they're $25 bucks. I think I broke my adjustment screw...but it comes on so w/e
or 16 whatev
WTB: LCA bushings
Old 10-30-2009, 06:01 PM   #7 (permalink)
Think there is a way to just hook up a window switch? Like for nitrous? Come on at certain RPMs? Or would that not be good with meth?
Old 11-02-2009, 10:32 PM   #8 (permalink)
Guess not.
Old 11-03-2009, 05:23 AM   #9 (permalink)
Trader Rating: (64)
yes, a window switch is nothing more than a switch. You may need a relay but it can be done. in your situation I think boost is better, but you can do RPM.
Old 11-03-2009, 03:18 PM   #10 (permalink)
Member Number: 75915
The problem with RPM based injection is: What happens if you do a hard downshift?
Bam, injection with the throttle plate closed. Unless you also have a throttle reference too. At which point you are getting sort of complex for whats supposed to be a simple system.
For a basic non-progressive system, boost is the best parameter 90% of the time.
Snow Performance Tech
SnowTech.4 is offline   Reply With Quote
Old 11-04-2009, 05:49 PM   #11 (permalink)
Well I know that Dynotune has a window switch that will only open IF RPMs are where they should be, and IF it is WOT. Used to have it on my nitrous set up.
Heres a link, 100 bucks.
DYNOTUNE
Old 11-08-2009, 03:09 PM   #12 (permalink)
Just curious. Where do people have the wires hooked up for the boost switch? Like to what wires? Straight to the battery? Or threw something else?
Old 11-08-2009, 06:42 PM   #13 (permalink)
Adionik's Avatar
Trader Rating: (25)
My meth stopped working...fuck.
I can't find my test light, i'm hoping it's just a wire or ground.
AFRs went to 12.0-12.3 and 3kr. Not too bad!
Old 11-09-2009, 04:42 PM   #14 (permalink)
If you need any tech help you can call me at 866-365-2762. Just ask for Derek.
Old 11-09-2009, 04:46 PM   #15 (permalink)
Trader Rating: (64)
First check to see if your injector is clogged. If you have our controller kit remove the hose to the injector, turn the key to the "ON" position and then ground the black pump wire to the chasis. If it sprays when you do that, your injector is clogged. Its the #1 scenerio.
If you do that test and it does not spray but the pump vibrates, you have air in the line and need to purge it. Remove the checkvalve and put back on (after you fill the tank).
could be boost switch, could be something else, but the two I outlined above will be the most likely.
CM
Page generated in 0.16141 seconds with 13 queries
