Old 08-14-2009, 03:10 AM   #1 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
Default anyone else using m2 additive
i use a tiny bit of upper cyl lube in my meth (non-cented) I am also flirting with RC fuel mix, any pro / con of lube or nitro mix
Old 08-14-2009, 05:22 PM   #2 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (122)
The typical W/A kit contains components that will eventually fail if the methanol being used contains additives.
VP M1 is near 100% pure and is known safe for the W/A components. M3 & M5 for example should not be used.
The blended methanol's being offered are designed for those using methanol as the primary fuel. For W/A injection stick to M1 or comparable.
Old 08-16-2009, 03:17 PM   #3 (permalink)
Member Number: 52407
Where are you guys getting M1?
7055 is offline   Reply With Quote
Old 08-16-2009, 03:51 PM   #4 (permalink)
turbojack's Avatar
Go here and click the location near you
VP Racing Fuels Contact
Call the number to find a reseller near you.
Page generated in 0.15891 seconds with 13 queries
