Will I need a Larger Fuel Pump? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-05-2012, 05:42 PM   #1 (permalink)
Member Number: 87400
Default Will I need a Larger Fuel Pump?
Hey Everyone,
I am in the process of having my SRT completely rebuilt. I picked this car up as a project car and it is now nearing the end of completion!
Here is the build thread
My SRT4 Build with ZMR Modifications
The car is still in pieces so I can not monitor the A/F ratios to determine the answer to this question. I do not have that much experience with SRT's so I figured I would throw it out there for you guys.
Mods are the following:
Stage 1 Injectors (04/05)
P&P Stock Turbo and Manifold
Intake
MPX 3" Catted DP
MPX 3" Exhaust
MPX 3" o2 Housing
1 Step Colder Plugs
Wires and Coil Pack
I do plan on getting a DSP and getting the care tuned.
Thanks you so much!
My DD: 2007 Stage 1 Supercharged Tuscani (SOLD)
Current DD: Hyundai Genesis Sedan 4.6 V8
My New Project: 2003 Neon SRT 4 (Completed)
ZeRoXceL is offline   Reply With Quote
Old 11-05-2012, 06:10 PM   #2 (permalink)
comatoast's Avatar
Member Number: 85196
Quote: Originally Posted by ZeRoXceL View Post
Hey Everyone,
Intake
MPX 3" Catted DP
MPX 3" Exhaust
MPX 3" o2 Housing
1 Step Colder Plugs
Wires and Coil Pack
Thanks you so much!
for that a 255 , BHF and return will be more than sufficient
Turbo / TB - AGP Zeta 3.0 / 28 psi , AGP bfmic, Boomba 70mm tb Engine - Wiseco 8.8:1 pistons .020 over , eagle h-beam rods , king main and rod bearings , DCR crank strap kit, Head - FnF race ported exh ports , +2mm rev exh valves , BC springs and Ti retianers , BC stage 4 cams (280*s) , Boomba cam gears,
Fuel - , 900cc fic inj , -6an feed and return lines , fuel pump rewire , bottle neck fix , Bosch 044 intank , aeromotive rrfpr , E85..
comatoast is offline   Reply With Quote
Old 11-05-2012, 06:53 PM   #3 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
He doesnt need a BNF or return line. A 255, rewire, and the stock injectors are good enough for the stock turbo.
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 11-13-2012, 07:57 PM   #4 (permalink)
Hey man,
Thank you so much! I ordered up me Wally 255 today
Old 11-13-2012, 09:09 PM   #5 (permalink)
triangles's Avatar
Member Number: 80981
Also a rewire would be good if you go with a255 don't want to burn up the pump you jut installed,
05 flame red
bw Stage 3 47lb 20g By Mole'
daily driven
E85
triangles is offline   Reply With Quote
