Old 09-13-2008, 04:56 PM   #1 (permalink)
Edgehold's Avatar
Member Number: 55411
Trader Rating: (35)
Default Wideband afr off after race gas
I went to the track last weekend and put about 4 gallons of Cam 2 110 octane leaded race gas w/ 6-7 gallons of 93 pump. Now my AEM wideband is reading 13.9 when cruising. Did the leaded fuel mess up the wideband 02 sensor or is something else the problem. Before it always read 14.9 ish when cruising. I need to know if the leaded gas could mess up the o2 sensors or if it just needs to be recalibrated. I thought that the manual for the AEM said that you could recalibrate it somehow.
Edgehold is offline   Reply With Quote
Old 09-13-2008, 05:31 PM   #2 (permalink)
mpbiv's Avatar
Member Number: 42
Trader Rating: (19)
Leaded gas will shorten the lifespan of O2 sensors (compared to regular gas). That being said, depending on the age of the sensor, and how often you run leaded race gas, the sensor might be at the end of its life.
If this is the first time you have run race gas and the sensor is fairly new, chances are the sensor is fine.
Flame Red SRT-4 (Old)...........Apex Silver EVO X (New)
mpbiv is offline   Reply With Quote
Old 09-14-2008, 08:46 AM   #3 (permalink)
Edgehold's Avatar
Trader Rating: (35)
thanks. I just got teh sensor over the summer and that was the first time I have ran leaded gas in it. So hopefully the sensor is fine, but that still doesn't tell me what is making it read in the 13's during cruise.
Old 09-15-2008, 09:16 PM   #4 (permalink)
Edgehold's Avatar
Trader Rating: (35)
I drove about 100 miles this weekend one way and there was no change. I filled up and put about 15 town miles on w/ no luck. Then I left and cruized the high way another 100. Somewhere in the last 100 it started reading back to normal. I don't understand why or what but I'm glad it's working right again.
Old 12-04-2008, 04:18 AM   #5 (permalink)
dragradial's Avatar
Member Number: 22291
Trader Rating: (13)
Maybe it took a bit for the lead to burn off.
dragradial is offline   Reply With Quote
Old 12-05-2008, 02:25 PM   #6 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
mine sensor is about 1.5yrs old..think its time to change it?
Old 12-06-2008, 01:05 AM   #7 (permalink)
93stang434's Avatar
Member Number: 49690
I use leaded race gas all the time and i think my AEM sensor is done when the car was tuned at rage-tek mine was off about .8 compared to the dyno.
E1 w/ported 3" anti-surge cover,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is offline   Reply With Quote
Page generated in 0.16545 seconds with 13 queries
