#1 (permalink) |
![]() Join Date: May 2008
Member Number: 63759
Started piecing together on my fuel system online. Looking to get a 1 gallon surge tank to mount in the batterys stock location. I've only briefly googled it...but where would I order a surge tank at lol. I wouldn't mind the passenger fender location either...just figured the stock battery location would be more secure incase of front end collision.
Stone White 05 - Stock Head & Bottom End - Holset HX35 7 Blade - e85 & many other supporting mods.
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
![]() Join Date: Dec 2009
Member Number: 76837
Would a small 1 gallon race cell fit your needs? Thats the cheapest solution that I came across.
Mod List: Built 2.4 with DCR Pro-Mod and a BW/AGP S-360RS along with every supporting mod. Currently 8psi a need bigger wheels/tires.
#3 (permalink) |
![]() Join Date: May 2005
Member Number: 28766
That's what I use. 1 gal aluminum fuel cell from summit racing. However, the cap seal will not hold up well if you use e85. I had my cap hole welded shut.
![]() 435 HP & 438 TQ -E85 Tuned by Turbo666 on his mustang dyno Best ET to date: 12.1 @ 124 on DR's |
#4 (permalink) |
1 gallon is plenty, and yes I plan to use e85. I didn't know Summit carried stuff like that, guess I shoulda looked there first lol. I plan to have -6an from tank, -6an return to tank, -6an return from regulator and -8an feed to a bosch 044 -8an to rail.
#5 (permalink) |
I think you're talking about this one: RCI Racing 2010A - RCI Aluminum Fuel Cells - Overview - SummitRacing.com - did you mount that in the passenger fender area?
#6 (permalink) |
That's exactly right. I had one more filling welded on and a frail welded in.
Here's and old picture. It's cluttered, and doesn't look good, but works.
#7 (permalink) |
![]() Join Date: May 2007
Member Number: 54011
im using a cxracing surge tank, bought it off ebay for around 70 shipped. I had pwerks weld a second outlet bung on in case i ever need 2 pumps, there weld quality is identical
:CXRacing Universal Aluminum Fuel Surge Tank 5"x9" Acura Integra Audi BMW | eBay They offer them with a ton of different fitting options, mine uses 8an outlets on the bottom, 2 above that were 6an, and very top was 8an (i just used a reducer)
#8 (permalink) |
![]() Join Date: Apr 2006
Member Number: 41218
IE Submerged 044 Billet Surge Tank WITH PUMP | Blue Water Performance
i like this one , not needing any more space for the pump |
#9 (permalink) |
^^^ yeah I like those. Had I seen those before I got my setup I would have gone that route.
#10 (permalink) |
i like this one , not needing any more space for the pump Good idea but overpriced in my opinion. SAMSUNG-SGH-I997 using Tapatalk
#11 (permalink) |
It's not too bad if you get the one without the pump and source your own 044 elsewhere. You can usually find them new from $150-180 if you look around.
#12 (permalink) |
Jay Racing's modifed 044 is $189 as well...considering that over the normal 044.
#13 (permalink) |
Oh just took a quick peek and seen the 400+ price tag.
#14 (permalink) |
Well, I went ahead and ordered that CX Racing one Masat03 is using. Ordered a bunch of fittings from Summit, placed order for a Jay Racing Pro Series 044 today, Denso 1200cc injectors as well as a bunch of other little stuff...hopefully this build will be promising!
#15 (permalink) |
Member Number: 76909
:CXRacing Universal Aluminum Fuel Surge Tank 5"x9" Acura Integra Audi BMW | eBay They offer them with a ton of different fitting options, mine uses 8an outlets on the bottom, 2 above that were 6an, and very top was 8an (i just used a reducer) ![]() bump to an old thread but can u tell me what out lets go to what im thinking of buying this surge tank
BOOST IS MY DRUG E85 IS MY NEEDLE ![]() |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
