Old 05-04-2006, 07:20 AM   #1 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Default Too much fuel is bad for your car.
All,
I'm reposting this as the other is gone from last year. This really needs to be a Sticky
Many are new to tuning turbo's and some SRT suppliers are selling fuel components to owners who need to be schooled up some. Innovate is a Engineering and Manufacturer of WB and other superior fuel and engine mangement components of the highest quality.
FYI,
Marion
By Klaus Allmendinger, VP of Engineering, Innovate Motorsports
Many people with turbochargers believe that they need to run at very rich mixtures. The theory is that the excess fuel cools the intake charge and therefore reduces the probability of knock. It does work in reducing knock, but not because of charge cooling. The following little article shows why.
First let’s look at the science. Specific heat is the amount of energy required to raise 1 kg of material by one degree K (Kelvin, same as Celsius but with 0 point at absolute zero). Different materials have different specific heats. The energy is measured in kJ or kilojoules:
Air ~ 1 kJ/( kg * deg K)
Gasoline 2.02 kJ/( kg * deg K)
Water 4.18 kJ/( kg * deg K)
Ethanol 2.43 kJ/( kg * deg K)
Methanol 2.51 kJ/( kg * deg K)
Fuel and other liquids also have what's called latent heat. This is the heat energy required to vaporize 1 kg of the liquid. The fuel in an internal combustion engine has to be vaporized and mixed thoroughly with the incoming air to produce power. Liquid gasoline does not burn. The energy to vaporize the fuel comes partially from the incoming air, cooling it. The latent heat energy required is actually much larger than the specific heat. That the energy comes from the incoming air can be easily seen on older carbureted cars, where frost can actually form on the intake manifold from the cooling of the charge.
The latent heat values of different liquids are shown here:
Gasoline 350 kJ/kg
Water 2256 kJ/kg
Ethanol 904 kJ/kg
Methanol 1109 kJ/kg
Most engines produce maximum power (with optimized ignition timing) at an air-fuel-ratio between 12 and 13. Let's assume the optimum is in the middle at 12.5. This means that for every kg of air, 0.08 kg of fuel is mixed in and vaporized. The vaporization of the fuel extracts 28 kJ of energy from the air charge. If the mixture has an air-fuel-ratio of 11 instead, the vaporization extracts 31.8 kJ instead. A difference of 3.8 kJ. Because air has a specific heat of about 1 kJ/kg*deg K, the air charge is only 3.8 C (or K) degrees cooler for the rich mixture compared to the optimum power mixture. This small difference has very little effect on knock or power output.
If instead of the richer mixture about 10% (by mass) of water would be injected in the intake charge (0.008 kg Water/kg air), the high latent heat of the water would cool the charge by 18 degrees, about 4 times the cooling effect of the richer mixture. The added fuel for the rich mixture can't burn because there is just not enough oxygen available. So it does not matter if fuel or water is added.
So where does the knock suppression of richer mixtures come from?
If the mixture gets ignited by the spark, a flame front spreads out from the spark plug. This burning mixture increases the pressure and temperature in the cylinder. At some time in the process the pressures and temperatures peak. The speed of the flame front is dependent on mixture density and AFR. A richer or leaner AFR than about 12-13 AFR burns slower. A denser mixture burns faster.
So with a turbo under boost the mixture density raises and results in a faster burning mixture. The closer the peak pressure is to TDC, the higher that peak pressure is, resulting in a high knock probability. Also there is less leverage on the crankshaft for the pressure to produce torque, and, therefore, less power.
Richening up the mixture results in a slower burn, moving the pressure peak later where there is more leverage, hence more torque. Also the pressure peak is lower at a later crank angle and the knock probability is reduced. The same effect can be achieved with an optimum power mixture and more ignition retard.
Optimum mix with “later” ignition can produce more power because more energy is released from the combustion of gasoline. Here’s why: When hydrocarbons like gasoline combust, the burn process actually happens in multiple stages. First the gasoline molecules are broken up into hydrogen and carbon. The hydrogen combines with oxygen from the air to form H2O (water) and the carbon molecules form CO. This process happens very fast at the front edge of the flame front. The second stage converts CO to CO2. This process is relatively slow and requires water molecules (from the first stage) for completion. If there is no more oxygen available (most of it consumed in the first stage), the second stage can't happen. But about 2/3 of the energy released from the burning of the carbon is released in the second stage. Therefore a richer mixture releases less energy, lowering peak pressures and temperatures, and produces less power. A secondary side effect is of course also a lowering of knock probability. It's like closing the throttle a little. A typical engine does not knock when running on part throttle because less energy and therefore lower pressures and temperatures are in the cylinder.
This is why running overly-rich mixtures can not only increase fuel consumption, but also cost power.
mario03srt is offline   Reply With Quote
Old 05-04-2006, 07:24 AM   #2 (permalink)
srtbee22's Avatar
Member Number: 22118
Trader Rating: (40)
sticky!!!!
srtbee22 is offline   Reply With Quote
Old 05-04-2006, 11:25 AM   #3 (permalink)
Member Number: 24039
I read this on the Innovate website. Good info and nicely explained so a moron like me can understand. Now if I could just my car out of the 9's and 10's without running a 20+psi spike. Anyone got any 03 stock injectors for sale? I guess I need a WI kit and my MAP Clamp hooked up.
Mods: Driving Light remove-cold air intake/ ram, Prothane MMI (race), K&N Drop-In, AGP WGA,3" EZR Downpipe, HP design 18x8 w/ 235 Sumo's, AEM UEGO, map clamp, check valve
Madrex is offline   Reply With Quote
Old 05-04-2006, 03:49 PM   #4 (permalink)
Member Number: 35361
He is giving you theroy, when you need practical info.
Not many people run 12:1 afr on pump gas in boosted motors, most people making damn good power arent even running that lean on race gas.
You need to consider the exception he listed in his message, like running water injection, or reducing the timing.
hostile is offline   Reply With Quote
Old 05-06-2006, 05:30 PM   #5 (permalink)
SRT-4 Technical Disscussion Moderator
Shifty's Avatar
Member Number: 19343
Trader Rating: (59)
Quote: Originally Posted by srtbee22
sticky!!!!
done
T1 Race Development
Tuned By Tony Palo
" Why would I pay a vendor $130 for something I can make for 29 cents ? "
Shifty is online now   Reply With Quote
Old 05-06-2006, 07:12 PM   #6 (permalink)
SRTNOOB's Avatar
Member Number: 9601
I agree with what is posted to the fullest but I must say that using "later" timing and a optimum a/f mix will equal sky high egt's.Am I correct in this thinking...opinions please....
"NO QUSTIONS ARE STUPID QUESTIONS" that's how we all learn at some point...
AGP WGA, My Custom Mounts,Stge 1,$20 Catch Can,3" Catless dp,sts,Zeitronix Wideband with egt,CTI Side Exit,CTI 02 Housing,CTI fmic,CTI Hardpipes,HKS SSQ bov,AGP return line,Kinetic TB,CTI cai,AGP 50 trim,750's,D-tec fbc
Maine's rep. for CTI
Sponsored by Rays Auto Tech
SRTNOOB is offline   Reply With Quote
Old 05-08-2006, 04:52 PM   #7 (permalink)
Acidryno's Avatar
Member Number: 106
I remember reading this.
Good info here, I think there is another part of it that talks about WI in the compression cycle.
The First SRT-4 in Louisiana.
www.ForgedMotorSports.com
Acidryno is offline   Reply With Quote
Old 05-08-2006, 05:10 PM   #8 (permalink)
boostking's Avatar
Member Number: 25195
does later mean advanced or retarded? If it means advanced i sure do believe that it would help decrease EGT's but someone will chime in with a reason
boostking is offline   Reply With Quote
Old 05-09-2006, 09:31 AM   #9 (permalink)
SRTNOOB's Avatar
Member Number: 9601
later=after or retarded timing
Old 06-29-2006, 07:34 PM   #10 (permalink)
arlo's Avatar
Member Number: 40243
this is all very true! the later timing will not increese egt's untill you retard it to far! we need to figure out how to retard it under boost with a map clamp at the same time! 12.7 has been proven to be max power on alot of dyno studies i have seen but the problem is timing! i am planing to use a water/alky system i build this weekend! i have a inovate wideband controler on order you can get into one for 200 bones. it will control your closed loop a/f programable via a lap top. it is a stand alone system you can add any a/f gauge to. and i belive if you get those a/f numbers down(part throtle and closed loop) it will pull the whole map down (max econamy is 17to 1 a/f) and at part throtle that is safe and then if you pin it it will hit like 12 to 12.5 wide open instead of 10.8 wide open and 14.5 closed loop. (i am trying to beet the gas prices as well we pay over 5$ a galon your dolar and galon size! I will post you some results when i figure it out! happy tunning all!
arlo is offline   Reply With Quote
Old 06-29-2006, 07:40 PM   #11 (permalink)
arlo's Avatar
"retarded" later timing casues the enging temp, and egt's to increese because the flame is traveling down the cylinder walls and pasing through the exhauste valve and out the pipe. all of wich soak up the heat! but only timing that is retarded to far if it is proper for the combination it will all be burnt before the valve opens ect. eg i belive the peak cylinder pressure should be around 18deg after top dead center so if you have a faster burning mix you need less timing!
Old 03-07-2007, 10:20 PM   #12 (permalink)
busarich's Avatar
Member Number: 25901
Trader Rating: (32)
Nice info, alot of people that I have seen on race gas run mid 12's afr, on pump 11.8ish.
MODS: Mostly stock
DYNO VIDEO - http://www.youtube.com/watch?v=NcQkdzEbry0
busarich is offline   Reply With Quote
Old 06-26-2007, 10:30 PM   #13 (permalink)
Member Number: 39105
Excellent post! Practical info is great, but when you understand why, then you can judge your own information from it, and bend the rules to the specific application.
esteinmaier is offline   Reply With Quote
Old 10-01-2008, 01:56 AM   #14 (permalink)
Member Number: 67647
If you have too much gas in your tank, it will just evaporate, expand or seep out. Usually fuel in the engine oil indicates a fuel leak either injectors or carb which ever the car is equipped with the smoke indicates that exsessive cylinder wall or piston ring damage may have allready occured when oil is mixed with gas it looses its ability to lubricate.
__________________________________________________ _________________
promotional products Tail Lights mens fragrance shop Sexual Predator List
peter2008 is offline   Reply With Quote
Old 10-02-2008, 10:36 AM   #15 (permalink)
arlo's Avatar
[quote=peter2008;6554796]If you have too much gas in your tank, it will just evaporate, expand or seep out. Usually fuel in the engine oil indicates a fuel leak either injectors or carb which ever the car is equipped with the smoke indicates that exsessive cylinder wall or piston ring damage may have allready occured when oil is mixed with gas it looses its ability to lubricate.
[quote]
We wernt talking about too much gas in the tank or in the oil or anything like that. we were talking about how rich or lean to tune the air fuel mixture! Maybe read the thread or at least part of it before responding to it!
