surge tank option - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-20-2012, 01:45 AM   #1 (permalink)
mattewhite04's Avatar
Member Number: 76009
Default surge tank option
currently have an in tank 044 with ID1000s doing e85.
Thinking about keeping the 044 intank and doing a intergrated engineering surge tank with built in 044 to Agp 1400cc. my goal is maxing my turbo out on e which is around 480-500.Is this overkill or will an 044 in tank and 1400s do.
BW255 .48ar 28psi, 100% E85
full bolt-ons,
built motor/CNC head
mattewhite04 is offline   Reply With Quote
Old 11-20-2012, 10:38 AM   #2 (permalink)
SRiceaTer4's Avatar
Member Number: 12671
Im pretty sure one 044 will do for that power level, I'm going with there dual 044 surge tank setup just so I never have to upgrade my fuel system ever lol 400 to 800 don't matter ill be good.
Black 04 SRT-4
RED 02 Neon ES = Daily driver.
SRiceaTer4 is online now   Reply With Quote
Old 11-20-2012, 10:50 AM   #3 (permalink)
SRT of the Month
2011 Calendar Car
1LAPSRT's Avatar
Member Number: 38267
I am using an IE single pump surge tank running E90 thru DW1300's making ~610whp. You can't feed a surge tank with a Walbro pump because there is no pressure on the line and they don't work without it. I have a DW301 pump in-tank and it works great. Deatschwerks is introducing a line of surge tanks as well in Q1 2013.
Modern Performance SRT4 - Dominating the road race community for over 5 years!
2012 MPx SRT4 Racing and Event schedule:
http://www.srtforums.com/forums/f77/...2012-a-627265/
Old 11-20-2012, 10:54 AM   #4 (permalink)
SRiceaTer4's Avatar
So I can't use the stock pump to feed the surge? I've been wanting to pm you about this cause I knew you were using this setup. Thanks
Black 04 SRT-4
Old 11-20-2012, 10:56 AM   #5 (permalink)
SRT of the Month
2011 Calendar Car
1LAPSRT's Avatar
Nope. Without any pressure on the line the Walbro just spits and sputters. Unless I got a bad one, but it was a brand new HP 255.
Old 11-20-2012, 11:30 AM   #6 (permalink)
a853rox's Avatar
Member Number: 1907
You may have had a bad pump Doug.
I have a 255 in tank, feeding a surge tank containing an A1000 in it and have not had any issues with the 255....
Your Turbo, Cylinder head, and performance experts!
Bob Schreiber
Owner, Form and Function Performance LLC
Product Development, Cylinder head specialist for RavenWorks LLC
612-385-0419
a853rox is offline   Reply With Quote
Old 11-20-2012, 01:47 PM   #7 (permalink)
Member Number: 3797
I'm thinking bad pump too.
OP: That will be way more fuel that you need to get to 500, but it will leave you room to grow.
2003 SRT-4 Silver, AGP GT3076R on E85 DD!
Was 478hp/508tq ----> Now ???
2002 Camaro SS M6, going N/A...
enginjoe is offline   Reply With Quote
Old 11-23-2012, 07:49 PM   #8 (permalink)
Member Number: 74277
radium auto also makes surge tanks and also
Radium Store
034motorsports
Fully Enclosed FP34 044 Fuel Surge Tank - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
if you want to look at other designs
trinity_rush2001 is offline   Reply With Quote
Old 11-23-2012, 10:11 PM   #9 (permalink)
Vendor
Member Number: 37310
I agree with bad pump as well. Mine os setup that way and so is Jt among many others.
Pm me for your performance modified clutch fork,Big turbo and oiling port needs.thumbsup:
I buy clutch fork cores.[/B]
http://Wikyd-performance.com
Wonderer876 is offline   Reply With Quote
Old 11-23-2012, 10:36 PM   #10 (permalink)
SRT of the Month
jtm0n3y's Avatar
Member Number: 45372
Well it depends on how Doug had his setup - was he still using the stock FPR/Filter? If so, there was pressure in the line from that. If he was trying to feed a surge tank through a bottleneck fixed canister with a 255 in it then I couldn't really tell you how well that will work.
I'm using a 255 with stock feed line and FPR/Filter all the way to the front of the car then it's adapted to a -6an male end off the stock 5/16 hard line and from there it runs into the surge tank. No problems at all!
PM Wonderer876 for all your clutch fork, porting, and powder coating needs. Purchase online at
Wikyd-Performance.com Like us on Facebook!
You're retarded if you don't contact Sir Nigel Alexander/Turbo666 for Diablo Sport/CMR tuning.
jtm0n3y is offline   Reply With Quote
Old 11-23-2012, 10:55 PM   #11 (permalink)
Braindead's Avatar
Member Number: 63012
There is another option to Integrated Engeneering. Might want to take a look at 034motorsports. I have one that I will be installing next week.
Sorry Trinity didn't see ur post
Braindead is offline   Reply With Quote
Old 11-23-2012, 11:13 PM   #12 (permalink)
SRT of the Month
jtm0n3y's Avatar
Buy a surge tank from turbo666 ... exact replica of my setup. Then just run your pumps external.
Old 11-24-2012, 07:41 AM   #13 (permalink)
SRiceaTer4's Avatar
I'd rather have the pumps submerged, keeps the pumps cooler and less noise. Plus it takes up less room.
Black 04 SRT-4
Old 11-24-2012, 09:49 AM   #14 (permalink)
^ True ill see if i can max out the single 044+ ID1000s first. replacing my sock from a jay racing to the mesh steel sock from fuelab to see if it fixes my lean issues.
full bolt-ons,
Old 11-25-2012, 06:54 PM   #15 (permalink)
Racerxvsspeedracer's Avatar
Member Number: 32196
Does anyone know the fuel tank sending unit opening?I.D in."
Lot's of options.. surge/sump and many ways to do both.
I want it for road racing, I'd like to use a bigger tank like 16gal.
So I don't like most of the surge tanks out there, the sump would work perfect with a steel fuel tank. Like the one the 1st gen neon uses... and it would be a baffle sump with 2 external fuel pumps. I like one surge tank out there, the rest seem to be $$ suckers IMO
17x8 245/40/17 ST40 BBK Project TRAIN DONE!11/13/09
04 -E-85 Ported Stock Turbo,Stock cams&Head,Stock Motor,Safc Neo
329.69Hp, 395.77Tq STD 297Hp@6K 320.87Hp, 385.18Tq SAE
WTB Locked DSP,Built 5speed,SCT Prp
Racerxvsspeedracer is online now   Reply With Quote
