Old 09-29-2009, 07:40 PM   #1 (permalink)
04srt-4's!nEvErHiDe!'s Avatar
Member Number: 62487
Trader Rating: (31)
Default Stumped!!
okay so i am running my own custom fuel system, and i am planning on hard wiring an external fuel pump to a switch. now will the computer trip balls if i take out the fuel pump relay? and tuning, i will be using a safc, does tuning through the safc have anything to do with the fuel pump of does it just reduce the injectors duty cycle?? thanks for the help
for sale:CF narrowband, stock cams,
04srt-4's!nEvErHiDe! is offline   Reply With Quote
Old 09-29-2009, 09:50 PM   #2 (permalink)
Member Number: 58399
Trader Rating: (36)
the afc shouldnt have anything to do with the fuel pump, not real sure what you mean on the rest
DCR Powered
tcglass1 is offline   Reply With Quote
Old 09-30-2009, 12:53 AM   #3 (permalink)
Trader Rating: (31)
okay that's basically all i wanted to know, thanks
Old 09-30-2009, 03:09 PM   #4 (permalink)
duster360's Avatar
Member Number: 45182
The PCM does't care about the fuel pump, but I would strongly suggest using the same pump relay single wire from the PCM to energize your new fp relay.
Use the 12v DarkBlue/White wire and the Brown PCM ground to energize your relay. Be sure to keep the 15a fuse
Old 09-30-2009, 06:44 PM   #5 (permalink)
Trader Rating: (31)
awesome thanks duster , what would be the benifits of using the pcm to power the new fp relay?
Page generated in 0.13325 seconds with 13 queries
