Old 10-28-2008, 10:05 AM   #31 (permalink)
Member Number: 51111
For the record Aaron Neon also gets his from the Fuel Injector Clinic (or at least gets them tested there, that's what the flow chart I got came from)
1998 LS Integra - b18c swap, b16 transmission, CTR cams, milled head, Crome Pro, SC61, Revhard Mani, Johnny Racecar FMIC, walbro, RC 650's, self tuned...STOLEN!! = (
2003 Neon SRT4 - AGP 50 trim, DiabloSport Predator AND SAFC, 650cc's, home made return line, walbro, MPx FMIC, 5 layer HG, BC 2mm+ valves,self tuned...The kill list is long, but has come to an end. Now lets begin the quest for deep 10's...pump gas nitrous assisted
lVlemphizStylez is online now   Reply With Quote
Old 11-15-2008, 04:06 PM   #32 (permalink)
redsoxsrt's Avatar
Member Number: 28768
Trader Rating: (51)
i have a set of 615's from aaron, on my stage 3 and the car runs perfect. it actually idles smoother than the stage 2 injectors. so just DOOO IIIIITTTTT lol
Old 11-15-2008, 09:05 PM   #33 (permalink)
Novak94's Avatar
Member Number: 45523
Trader Rating: (10)
dam i need to pick some of those up...
Old 11-17-2008, 06:10 PM   #34 (permalink)
ade99's Avatar
Member Number: 17129
I also have these injectors (615ccs) on my Stage3 with FM's 44lb wheel. But when I got my car dynoed, it was running really rich between 3K-5.5K. So rich that it was below the 10AFR line (off the chart) and my car was bogging. This is all Stage3 PCM controlled. My car still made 395whp and 427wtq but I would've wanted to see what it could've made with a more ideal AFR. Would've been nice to hit the 400mark. So tempted to put back the Stage3 injectors just to see how much of a diff. it makes. Or just go with a return line maybe. BTW, this was on race gas and holding 24psi. Other significant mods are TKMS Walbro255, FMIC, AGP WGA, Hardpipes, 3"Dump, 62mm TB and Ported IM.
ade99 is offline   Reply With Quote
Old 11-17-2008, 08:15 PM   #35 (permalink)
Member Number: 35913
Trader Rating: (15)
Default ade99....q for U
ade99...you running the full stage 3 fpr and rail (i.e. 75 psi from the pump), or the standard 58 psi with 255?
TomC3 is offline   Reply With Quote
Old 11-17-2008, 08:59 PM   #36 (permalink)
ade99's Avatar
I'm running full unmolested S3 fpr and rail.
Old 11-18-2008, 11:19 AM   #37 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (13)
I've heard that low end bog from several people with the bigger injectors & no SAFC to lean it out.
I listed the Government as a dependant on my taxes this year.
Want health care? Get a better job or join the Military
Socialism - Tax dollars at work for those that don't.
Work harder, millions of people on welfare are depending on you.
srt4geezer is offline   Reply With Quote
Old 11-18-2008, 11:34 AM   #38 (permalink)
you get the same bog with the SAFC...it happens if you run a static pressure that's too low
Old 11-18-2008, 02:10 PM   #39 (permalink)
nickobsrt4's Avatar
Member Number: 33834
Trader Rating: (20)
i have aaron's 625 inj ii love how the car feels with them
CAR IS SOLD!
stage 3 fm 44lb wheel ,boltons, aem f/ic , maxxfab see, bc stage 2 cams, lots more tuned by Aaron@realtune
nickobsrt4 is offline   Reply With Quote
Old 11-18-2008, 02:26 PM   #40 (permalink)
90VNT's Avatar
Member Number: 1631
Can't see how people can use them without pulling fuel so the car isn't rich as hell.
90VNT is offline   Reply With Quote
Old 11-18-2008, 03:17 PM   #41 (permalink)
nickobsrt4's Avatar
Trader Rating: (20)
well i have stg 3 pcm with returnline set at 62 psi static and lft are like 10 and sft are around 6 not to bad annd the pcm is so good it puts the afr in ck at 14.7 15.5 with my setup that runs me to about 11.6 afr in third gear and 10.8 in fourth car drives stock no stumbles like some other inj
Old 11-18-2008, 03:21 PM   #42 (permalink)
90VNT's Avatar
Member Number: 1631
You are not using the S3 fuel rail. Completely different results.
Old 11-18-2008, 03:31 PM   #43 (permalink)
Monster's Avatar
Member Number: 48761
Trader Rating: (74)
Why?? I would think you could mock the s3 fuel system with a returnline. A local here ran a returnline with his s3 setup on a 03 rail with a walboro and it ran identical to a s3 fuel setup.
DSP + FPGreen 47lb S3 =
www.pt-performance.com
FS:Strapped Block,evo turbo and more..
FS:Axle,Viperseat and more!
Old 11-18-2008, 03:31 PM   #44 (permalink)
nickobsrt4's Avatar
Trader Rating: (20)
yep i agree but u wanna trade rails ?lol
Old 11-18-2008, 03:33 PM   #45 (permalink)
90VNT's Avatar
Member Number: 1631
S3 rail has its own regulator, it doesn't provide a constant fuel pressure. Pressure varies with boost.
