Old 08-27-2005, 09:03 AM   #31 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
Quote: Originally Posted by ROCKY_7_11
might be a dumb question but why do stage 2 and stage 3 have different flow rates if there are using the same injectors??? i dont think the new fuel rail could have changed the flow.
Bump this.... I also found this strange since we are measuring strictly the injector flow at the given fuel pressure in the table. If both S2 and S3 are using 682cc mopar injectors, how are we coming up with different flow rates?
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
Old 08-27-2005, 12:07 PM   #32 (permalink)
Member Number: 2584
Trader Rating: (35)
S3 is boost referenced while S2 is not (static).
So as boost goes up on S2, the effective fuel pressure drops while it's maintained on S3 (hence the later has more fuel).
funks is offline   Reply With Quote
Old 08-27-2005, 07:06 PM   #33 (permalink)
I understand how S3 uses a boost referenced regulator to keep the pressure constant, but if you look at the chart on the first page you will notice that the injectors in question were measured with a consnant pressure. This is strictly flow related with 2 given constant fuel pressures. They are 43.5 psi and 58 psi. Or in other words, the only thing in question here is, HOW DO S3 INJECTORS FLOW MORE THAN S2 INJECTORS WITH IDENTICAL FUEL PRESSURES WHEN THEY ARE BOTH 682CC INJECTORS? They are the same injector. And once more, just to make sure you understand the nature of the question, I am not asking how S3 delivers more fuel than S2. That's obvious. I'm asking how S2 & S3 injectors (mind you they are the same injectors) would have a different flow rate when converted to RC Engineering standards. I would prefer that the person who made the chart (SY04SRT4) answer this question since he knows what calculations he based his conclusions off of.
Old 08-28-2005, 12:17 PM   #34 (permalink)
Member Number: 2584
Trader Rating: (35)
I believe chad setup that chart a long time ago when it was speculated that S3R would be getting different injectors - not the same injectors as S2.
Old 06-20-2006, 10:33 AM   #35 (permalink)
Member Number: 42941
Thumbs up MOpar injector part# help!
Hey guys great forum! I need help with a part# of SRT4 inectors I have that I don't know if they are 2003 or 2004. The part# 04891574AB and below is 4073W10015. I don't have a SRT4 but I'm using this injectors in my project car which is a 1987 Mitsubishi Mirage 1.6L turbo with lots of engine mods. I made my own Port EFI and I'm using this injectors because they are high resistance and work well with Megasquirt. Right now I'm working on tuning the car but I found out that this injectors work at 58psi and not 43.5 that I'm using, beause it will hurt atomization. Now I have to raise the pressure to 58 and see what happens. The thing is that I don't know what year they are and what flow rate. When I bought them, they told me 440cc. Can you please help?
Thanks...
FOFO is offline   Reply With Quote
Old 08-22-2006, 07:40 AM   #36 (permalink)
Member Number: 41459
Trader Rating: (85)
Any chance of getting our DeatschWerks injectors added to the charts? PM me with any info needed to update them. Thanks
www.DWinjectors.com
DeatschWerks is offline   Reply With Quote
Old 11-14-2006, 06:14 PM   #37 (permalink)
hercfe's Avatar
Member Number: 19255
Just a FYI for all who don't want to do the math...The PTP FPR 80psi mod+S1 577cc injectors=677.65cc @ 80psi. S2 injectors @80psi are 800.968cc
hercfe is offline   Reply With Quote
Old 11-19-2006, 09:24 PM   #38 (permalink)
TNT
Member Number: 29877
Trader Rating: (17)
Do the following numbers/info seem correct?
"RC Engineering uses 760 -770 kg/m^3 as the density of their test fluid.
Mopar uses n-heptane which has a density of 685 kg/m^3."
_________________________________________________
Using the equation from the sticky:
(sqrt(new pressure/old pressure))(old flow rate) = new flow rate
Stage 2 injectors: (using n-Heptane liquid)
@58psi = 682cc/min
@43.5psi = 590cc/min
Are the following conversions correct?
if stage 2 injectors were rated using RC engineering liquid (assuming their liquid is 765 kg/m^3):
@58psi = 762cc/min
@43.5psi = 659cc/min
to get those numbers, use the following (@43.5psi): 590/765 = x/685 and solved for x
I'm just checking my options for fueling a higher flowing turbo set-up.
I already have stage 1 and 2 injectors and want to find a rating system that is equal....
Using different testing fluids seems like comparing apples to oranges.
TNT
SOLD... 2005 SRT-4 ACR - Black, 1 of 433 built, no Kicker or Sunroof
PTPerformance (253)653-3843
Shop hours 10am to 7pm PST
TNT is offline   Reply With Quote
Old 12-15-2006, 07:54 AM   #39 (permalink)
tgspeedracer's Avatar
Member Number: 25328
is there a rule of thumb for what size injector will suport so much hp?
Best ET 11.41
Best MPH 131
@5860ft elevation
Peak whp 567
Peak tq 607
DSP Tunned by Nick Chestnut with "Unique Solutions Tuning"
tgspeedracer is offline   Reply With Quote
Old 12-16-2006, 11:19 AM   #40 (permalink)
Yes. There is a formula for it. It is as follows:
Injector Flow Rate (cc/min) =
Engine HP x BSFC x 10.5
Number of Injectors x Injector duty cycle
BSFC (Brake Specific Fuel Consumption) varies depending on the type of induction. Here's a breakdown:
* For naturally aspirated engines, estimate BSFC to be 0.4 to 0.5
* For nitrous engines, estimate BSFC to be 0.5 to 0.6
* For forced induction, estimate BSFC to be 0.6 to 0.7
* For rotary engines, estimate BSFC to be 0.6 to 0.7
* For engines running methanol, double the appropriate gasoline BSFC (e.g. a forced induction methanol engine has a BSFC between 1.2 and 1.4)
Injector duty cycle should be around 80%, so where the equation asks for duty cycle, use .8 for the value.
example: 400 Hp Turbocharged 4 cylinder
400(HP)*.6(BSFC)*10.5=2520
4(injectors)*.8(duty cycle)=3.2
2520
3.2 =787 cc injectors
(note: The equation bases calculations off of an assumed fuel pressure of 43.5 psi. Different fuel pressures will result in different needs in injector size.)
Now you must remember that all this is theoretic, so it has margin of error. It's absolutely possible to achieve 400 HP+ on 750cc injectors, and has been proven time and time again. In fact, I believe it's been done with 650 cc injectors, but usually requiring higher duty cycle, and higher fuel pressure. So take all this theory with a grain of salt.
Old 03-17-2007, 09:45 AM   #41 (permalink)
Member Number: 11361
I was curious what the injectors would do at different fuel pressure, soooo... Using chuck's_srt-4 HP formula & modifying SY04SRT's xls...
( good link boost injector flow http://autospeed.drive.com.au/cms/A_107986/article.html )
here's the link http://i155.photobucket.com/albums/s...math-fixit.jpg
here is the raw numbers..
Injector cc/min cc/min cc/min cc/min HP (max) HP (max) HP (max) HP (max)
Fuel Pressure (lbs) 43.5 58 80 100 43.5 58 80 100
Mopar Stage 0 456.4 527.0 618.9 692.0 231.8 267.7 314.4 351.5
Mopar Stage 1/ 2004 SRT-4 Stock 499.7 577.0 677.7 757.6 253.8 293.1 344.2 384.8
Mopar Stage 2 590.6 682.0 801.0 895.5 300.0 346.4 406.8 454.9
Mopar Stage 3R 590.6 682.0 801.0 895.5 300.0 346.4 406.8 454.9
RC Engineering 550 550.0 635.1 745.9 833.9 279.4 322.6 378.9 423.6
RC Engineering 650 650.0 750.6 881.5 985.5 330.2 381.2 447.7 500.6
RC Engineering 750 750.0 866.0 1017.1 1137.1 381.0 439.9 516.6 577.6
RC Engineering 850 850.0 981.5 1152.7 1288.8 431.7 498.5 585.5 654.6
fixit is offline   Reply With Quote
Old 05-27-2007, 08:55 AM   #42 (permalink)
TNT
Trader Rating: (17)
Too bad the #'s are off... The injectors must be tested with the same fluid or you are comparing apples to oranges... Which you are...
Which means if stage 2 injectors were rated using RC engineering fluid thier flow would be quite higher.
Stage 2 Injector flow with RC engineering test fluid.
@58psi = 762cc/min
Old 05-28-2007, 08:08 PM   #43 (permalink)
TNT, good catch.. thx!!!
i updated the XLS, here is the new link http://i155.photobucket.com/albums/s...th-fixit-1.jpg
<version 2, has 2 notes -- cut and paste of TNT's comments>
PCM=S0
injectors=S2($160)
S3R DCR manifold ($500) w/evo8 turbo (ebay $150)
MAP clamp/EBC (my own design-- parts $10)
Spring Mod (my design $5)
24x12x3 FMIC (generic $140 ebay special) - ugh
Filled Motor Mounts, Flexane $35
Valve cover, red -- Rustolium High Temp $5
ODB2 setup (scantool.net (ebay $70), DigiMoto software)
DataLogger DataQA, $25
Wideband LC1 (ebay $165)
wheels=16x8.5 w/245/45/16
needswing v5 <forums $60>
Next
3" O2 ,WI_DIY
Old 08-26-2007, 06:30 PM   #44 (permalink)
dodgez's Avatar
Member Number: 1795
Trader Rating: (15)
Making the RC750's flow like stage1 injectors. From what I have figured out is that the rc750's would have to running 25psi to flow 55lbs/hr or 577cc. I don't think the injectors will work right at that low of PSI.
Can't spell and have bad grammar??? click here
Quote: Originally Posted by red04@FM
You don't know anything. Look at the time it took for him to get back to us. We do more then what we should to help out customers.
dodgez is online now   Reply With Quote
Old 10-31-2007, 07:04 PM   #45 (permalink)
Member Number: 46363
Trader Rating: (38)
Maybe Im reading this way wrong but... If stage 2 injectors are considered to flow 769cc at 58psi (RC fluid) and RC 750's flow 866ccs at 58psi, then I should start by pulling 11% fuel globaly? Or for that matter if static pressure is 43.5psi ([659/750]-1) then pull 12% of fuel globaly??
~~After looking more closely (once again I may be retarded here), but If I have a stage 2 PCM (stg 2 injectors = 761.6 cc's @58psi) and run my RC 750's at 43psi.... shouldnt I be adding 1.5% of fuel as a baseline?(761.6/750-1= .015xxx)
Bryan Tracy
04 Silver SRT4 - Parted and Sold
05 Aero Blue SRT-6 - New Toy
ImportLabSRT4 is offline   Reply With Quote
Page generated in 0.22491 seconds with 13 queries
