Old 08-27-2004, 04:41 PM   #1 (permalink)
SY04SRT4's Avatar
Member Number: 3903
SRT-4 Common Injector Flow - Math/Info/Chart!
I have seen a lot of posts and confusion about the commonly available injectors for the SRT-4 lately. Here is some math and some numbers to help clear it up. Add what u can! Maybe we can get a sticky!?! If anyone knows of any other injectors available PM me and I will add them!
*Thx to RC Engineering for some of the info! All flow numbers are rounded down to the nearest whole number.
The Mopar injectors (S0, S1/04, S2, S3R) are rated at 58 PSI fuel. Most aftermarket injectors and most OEM injectors are rated at 43.5 PSI.
The conversion to get a new flow rate at a new pressure is:
I also made a nice excel chart.
HERE is the link for excel format.
2004 SRT-4 BEE-OTCH!! <<Under Construction>>
AGP Delta 55, FIC 1150's, Magnafuel 625 etc...
SY04SRT4 is offline   Reply With Quote
Old 08-27-2004, 04:58 PM   #2 (permalink)
Rydiak's Avatar
Member Number: 12643
Awesome idea! This will make things easier.
2004 Dodge Neon SRT-4 - Stage 3 [Sold]
2005 Chrysler Crossfire SRT-6
Quote: Originally Posted by RTShadow
Any muffer a six month old toddler could trip and fall into is rice.
Rydiak is offline   Reply With Quote
Old 08-27-2004, 05:33 PM   #3 (permalink)
cali's Avatar
Member Number: 159
a little birdie once said the mopar injectors arent flowed with the same liquid as aftermarket. Dont think it makes MUCH difference, but just throwing that out there from a birdie.
someone is watching me
Old 08-27-2004, 05:36 PM   #4 (permalink)
Rydiak's Avatar
And that little birdie failed to notice that SY04SRT4 already took that into account. :P
Old 08-27-2004, 06:04 PM   #5 (permalink)
cali's Avatar
Member Number: 159
I must have missed it....it in written in white?
Old 08-27-2004, 06:06 PM   #6 (permalink)
Member Number: 11555
so why is psi-fi doing some funky calculations with their 530cc/min injectors? They say it flows more than the S2 even though it doesn't
S2 = 590 cc/min @ 43.5 psi, PsiFi Injectors == 530 cc/min @ 43.5 psi
ToFu is offline   Reply With Quote
Old 08-27-2004, 06:28 PM   #7 (permalink)
Jeremy's Avatar
Member Number: 2305
Here ya go, from a PVO source:
I called RC and it sounds like they use 760 -770 kg/m^3 as the density of their test fluid. We use n-heptane which has a density of 685 kg/m^3. An injector's mass flow is dependent on the density of the fuel. If two different fuels are flowed through the same injector, the volumetric flow rate of each fuel should be the same. This said, both sets of numbers for the injectors that you have are wrong. The correct numbers are as follows:
For n-Heptane @ 58 psi,
2003 Injectors - 359.4 g/min = 47.4 lb/hr = 524.7 cc/min
2004 Injectors - 395.3 g/min = 52.2 lb/hr = 577.1 cc/min
RC Engineering and most aftermarket injector companies flow their injectors at 43 psi. Using Bernoulli's equation, the mass flow can be corrected to:
For n-Heptane @ 43 psi,
2003 Injectors - 309.5 g/min = 40.8 lb/hr = 451.8 cc/min
2004 Injectors - 340.4 g/min = 44.9 lb/hr = 496.9 cc/min
If RC Engineering flowed our injectors with their test fluid @ 43 psi, they would rate the injectors as follows:
2003 Injectors - 343.3 g/min = 45.3 lb/hr = 498.3 cc/min
2004 Injectors - 377.6 g/min = 49.8 lb/hr = 547.8 cc/min
Basically injectors are volumetric flow devices, so a more dense fuel will flow more mass flow than a less dense fuel at the same volumetric flow rate. This is a very confusing subject. As you can see, it is very easy for a company to skew their flow ratings in their favor. There will always be some error in ratings until all injectors in question are flowed on the same test bench with the same test fluid at the same test pressure.
Jeremy is offline   Reply With Quote
Old 08-27-2004, 07:02 PM   #8 (permalink)
SY04SRT4's Avatar
Member Number: 3903
Exactly... Technically there would be no way to tell without eliminating all the variables. I just thought there should be a post about it. I guess I skimped on the research!
The numbers can be adjusted based on fluid density as well. That should be no problem, we can get fairly close. #'s to the .XXX okay? It does make a difference.
Old 08-29-2004, 08:08 AM   #9 (permalink)
Member Number: 180
so then what do the s1 injectors "really" flow at 58 psi? might make a difference in the injector size change on an e-manage.
NeonWaSp is offline   Reply With Quote
Old 08-29-2004, 08:55 AM   #10 (permalink)
SRT-4 Neon's Avatar
Member Number: 1573
I entered 500cc/min as Hector suggested and things are running perfect on my emanage.
C
Damn it, Have a nice day...
11.9@121 Bithlo
SRT-4 Neon is offline   Reply With Quote
Old 08-29-2004, 09:50 AM   #11 (permalink)
Member Number: 1408
Cool
Thank you for taking the time to make that spreadsheet!
2003 SRT-4
chris6543 is offline   Reply With Quote
Old 08-29-2004, 05:05 PM   #12 (permalink)
Member Number: 180
why enter 500? i understand thats what they are at 43.5 psi but s1 injectors at regular pressure the computer expects to see 577, not 500.
so any idea what s1 injectors at 58psi of the rc rated flow is? still curious.
Old 08-29-2004, 09:02 PM   #13 (permalink)
Member Number: 180
you're an idiot. before you "raise" your tone perhaps try reading fully my above post where i specifically mention at 58psi.
here, i'll spell it out better.
rc uses a different density of fluid than does chrysler for rating injectors. in this thread there is no mention of what the chrysler injectors flow at 58 psi using the same density of fluid that rc does. what i would like to know, again, is what rate of flow the chrysler injectors have at 58 psi using the same density as the rc's.
Old 08-30-2004, 06:19 AM   #14 (permalink)
cali's Avatar
Member Number: 159
Why dont u pay and get them flow tested for the benefit for the community?
Old 08-30-2004, 06:30 AM   #15 (permalink)
Member Number: 180
i'm not that interested :P
i was hoping someone who knew how to do the math would plug in the numbers.
Page generated in 0.18871 seconds with 13 queries
