#16 (permalink) |
![]() Join Date: Feb 2008
Member Number: 61336
I've heard guys going to 1/8th tank with no issues at all. Which is impressive, I was having issues at 1/4 with feed hose inside tank
Sent from ![]()
'freedom's not free'
24-25psi 61mm 11.6@120 @3650ft |
| Sponsored Links | |||
Advertisement | |||
#17 (permalink) |
SRT of the Month ![]() Join Date: Aug 2005
Member Number: 32888
I know the point of the sump. Lol. But I'm always over worried about situations. Say fuel light is on left or right hand corner with a bump. Fuel settles somewhere else in the tank for a short period of time and pump sucks air. Then you could always argue the fact not to drive like a jackass on low low fuel levels also. Lol Obviously I don't have experience with a sump. So I would ask the questions before just diving in.
That's the only reason I haven't bought the sump. I had a extra canister and started to mod it for the 044. The sump seems like less of a headache if something goes wrong. Sent from ![]() ![]() first you have to know how a fpr works... then you will understand that you will be ok,,, also good idea to fill up before 1/8 tank the fpr will regulate the pressure before the regulator the unused fuel is returned to the tank, if for some reason your running low on fuel you will not return as much to the tank, the fpr will do everything in it power to keep the fuel at your set value, by returning more or less fuel.... Yes at some point it will return no fuel and u will run out. O
#18 (permalink) |
![]() Join Date: Aug 2011
Member Number: 85871
Thanks for the heads up. 1/8 tank is very low. But we all been there and not a station around.
Yea chief I'm trying to avoid the pick up issues you were having with the in tank. Makes more since now thanks UnderSRTarmour and chief. Sent from ![]()
2003 Solar Yellow
12.79 @108.23 |
#19 (permalink) |
![]() Join Date: May 2010
Member Number: 79119
Chief what kinda power ya making and what fuel are you using? Also correct me if I am wrong a single 044 can push 500 on e85 correct? Also that's the brand I been looking at is the beans performance. I like the little drain and it looks quality.
05 SRT-4 Custom 3 inch downpipe, JMB TiAL hard pipe, DSP 93 Octane tune, Mopar short shifter,Boomba fuel rail, Saikou Michi dual catch cans, BWoody Solid motor mounts, AGP solid trans mount, DCR 4th mount, DCR Oil pump, DCR Direct fit 6061 strap kit, DCR oil pick-up, MPX Big oil filter kit, ProAuto clutch line,PWerks small battery, BC BR coilovers, MPX solid LCA's, CBD ELW lip, Stern ST-1 |
#20 (permalink) |
Idk I don't know what power i making but I plan on running 28-30 on a 6262 with e85 dual jays n 1150s will see.
Sent from ![]()
#21 (permalink) |
![]() Join Date: Aug 2010
Member Number: 80981
Any where else I can get a sump like that 165 $ is kinda pricy I think . I need to install one on my car 1/2 tank with new set and getting screeching from the pump. I'm also -8an (1/2inch ) fuel line to the pump.
Just curious If I just just the pick up line to sit in the orginal fuel cansiter will that work of I put the line twords the end of the cansiter ? Sorta like a internal sump ?
05 flame red
bw Stage 3 47lb 20g By Mole' daily driven E85 ![]() |
#22 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
I ran tweeks car down below a gallon and the car drove fine. I wouldnt go wot with that little fuel in the car.
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ |
#23 (permalink) |
What's the max horsepower on a single 044 on e85?
#26 (permalink) |
![]() Join Date: Mar 2011
Member Number: 83534
You could always do a Full Blown dual pump set-up. That way you wont have to cut your fuel tank and what not. Just throwing it out there.
College > Everything I want
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
