Old 11-25-2008, 09:23 PM   #1 (permalink)
meatman's Avatar
Member Number: 69232
Default safest octane level?
whats the highest octane i can run in a stock srt 4 without damage or waste?
meatman is offline   Reply With Quote
Old 11-25-2008, 09:29 PM   #2 (permalink)
TurboMoparGod's Avatar
Member Number: 33697
Trader Rating: (56)
IMHO Unleaded 105. Anything higher in octane then that is a waste on your stock setup.
Forward Motion 302-658-2829
http://www.forwardmotioninc.com/html...og/page18.html
Sales@ForwardMotioninc.com
Stock turbo 12.82@107mph DR's
E1 Turbo 12.48@115mph DR's slipping stock clutch
E3 47lb Turbo times to come
TurboMoparGod is offline   Reply With Quote
Old 11-26-2008, 08:11 AM   #3 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
I ran 110 leaded on my stock turbo, usually cam2 or turbo blue. My car loved that stuff!
S256 non extended tip F/IC tuned by Aaronneon
11.88@116 1.74 60'
Old 11-26-2008, 10:44 AM   #4 (permalink)
Member Number: 31622
Unless you've tuned your car to take advantage of added octane (higher boost, more timing, etc..) then anything above premium pump gas is a waste of money.
What kind of "damage" are you worried about?
'05 SRT-4
'87 Turbo-T
Got Boost?!
CaptainInsane-O is offline   Reply With Quote
Old 11-27-2008, 10:46 AM   #5 (permalink)
meatman's Avatar
Default just wondering
im just looking to get the most out of my stock setup untill i can start upgradeing and dont want to use a high octane if it is going to hurt or waste im pretty new to my srt 4 so any info helps
Old 11-28-2008, 08:09 PM   #6 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
leaded fuel will build up on sensors (o2) and running a super high octane can result in very high EGT's and a loss of power if you don't tune for it
so your answer is a stock un-modded car 93 oct
stock modded (clamped) W/ high boost 97+ oct depending on the clamp
remember higher oct burns slower (and has a higher flash point ) so it will do almost the same thing as retarding your ignition if misused
Old 11-29-2008, 10:12 AM   #7 (permalink)
meatman's Avatar
Default clamp?
what are you talking about when you say clamped and the fine tunning you are talking about is that something i can do my self or will dodge do that for me?
Old 11-29-2008, 10:22 AM   #8 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
86 octane piss, thats what I run, spiking to 30+psi, holding 28, with 40 degrees of timing, with no knock. I was running a 12.9-1 AFR, hoping to lean it out to about a 14-1, 1800-1900 degree exhaust temps FTW see if I can pick up a extra 20 or so HP!!!!
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 11-29-2008, 10:36 AM   #9 (permalink)
Actually, if you don't re-tune for higher octane your car will just run rich...
Also, race gas doesn't burn any slower than regular pump gas it simply takes more energy to initially light-off.
Meatman, go to the Performance Modifications forum on this board ( Performance Modifications - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum ) check out the "stickies" section & read up on the basic modifications / go-fast how to's.
Old 11-29-2008, 01:07 PM   #10 (permalink)
Trader Rating: (30)
I was tuned on a ptp map clamp, ran 110 leaded most of the time and only went thru 1 upstream o2!
Old 11-29-2008, 08:26 PM   #11 (permalink)
nutz's Avatar
Trader Rating: (19)
yup actual flame propagation speed has little to do with the octane rating, but i always feel people can understand this better
and i would recommend some good books not the srt forums sticky section
Old 12-01-2008, 11:18 AM   #12 (permalink)
Member Number: 52407
If you're stock then I think 93 or slightly higher is the best. I had knock on 91 & 92 bone stock according to my scangauge. I think it helped my traps a little with the higher octane because it wasn't pulling timing. You can't hurt your car from running to much octane but you can from to little.
7055 is offline   Reply With Quote
Old 12-07-2008, 12:04 PM   #13 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
, I was getting ready to make a comment but you beat me to it. I wonder if we should confuse them now with specific weight gravity of fuels and how that effect the total flow numbers and flame propagation?
OP, don't waste the money on the race gas unless you know you have knock. Spend the money on a good gauge or scan tool to measure knock.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Page generated in 0.25594 seconds with 13 queries
