» Tire Upgrade Garage
Old 05-07-2008, 10:24 PM   #1 (permalink)
Member Number: 45523
Default S3 Rail pressure gauge ???
Ok so i have seen many people with the Stage 3 rail and they are running a mech. pressure gauge on the pressure test port on the right end of the rail. I am interested in doing the same but im not to familiar with what fitting i need and what size.
Here is the page i was looking at, could someone suggest what one i would need?
Fittings
Here is the gauge i was looking at too:
Gauge
Thanks guys i appreciate any replies!
Old 05-11-2008, 12:52 AM   #2 (permalink)
Old 05-11-2008, 10:36 PM   #3 (permalink)
Old 05-13-2008, 07:26 AM   #4 (permalink)
wiggyx's Avatar
Member Number: 58107
Not sure about fittings, but you will def need the 0-100 psi version of the gauge.
Old 05-13-2008, 10:35 AM   #5 (permalink)
KBzPTGT's Avatar
Member Number: 112
Russell AN Female to AN Male Adapter Fittings with Pressure Gauge Port - JEGS
KB's 03' Elec Blue E1 powered PT Cruiser
Low n slo with rear suicide doors
60' 2.070
330 5.728
1/8 8.826
mph 79.62
1000 11.496
1/4 13.880
mph 90.06 <~~~
KBzPTGT is offline   Reply With Quote
Old 05-13-2008, 01:34 PM   #6 (permalink)
yep i plan on getting the 0-100 psi gauge. As far as the fitting goes ^^^ that is the exact one i was looking at, i just don't know what size the test port on the S3 rail is. Then as far as the other side of that fitting i will need some kinda cap that is meant to hold pressure, unlike the stock one on the s3 is just a dust cover.
Old 05-15-2008, 03:39 PM   #7 (permalink)
KBzPTGT's Avatar
Member Number: 112
the fuel pressure sensor fitting that came with my scangauge is a -4an fitting with a 1/8npt port. Todd @ AeroForce verified this is what we need for the
PTGT & SRT4 fuel rail. It comes with the cap you mentioned
Oil and Fuel pressure sensor page
Old 05-15-2008, 06:52 PM   #8 (permalink)
duster360's Avatar
Member Number: 45182
Todd at ERROR-farce is a moron. just add this one to his long list of F-ups
The test port is NOT -4 AN,,, I repeat it is NOT -4 AN,,, its 3/8-24 SAE flare.
-4AN will screw on but the AN's 37 degree flare DOES NOT match up well to the SAE flare of 45 degrees. Eventually it will leak.
heres an Earl's But you can pick up a SAE flare to NPT adapter from the hardware store.
4AN to 3/8 24 SAE flare
duster360 is online now   Reply With Quote
Old 05-15-2008, 07:21 PM   #9 (permalink)
KBzPTGT's Avatar
Member Number: 112
Thanks Duster for clarifing that. I didn't mean to pass on misinformation. I was just passing on what i was told. I guess I wasted my money on that part.
$25 bucks down the drain
Old 05-15-2008, 10:06 PM   #10 (permalink)
Duster360 - Thats exactly what i wanted to know, now i can get what i need
Old 05-16-2008, 07:05 AM   #11 (permalink)
duster360's Avatar
Send it back to Todd. He misrepresented the part. Its his own fault he doesn't know what the hell he's doing ,,not yours.
Better yet, mail it to me, I'll tie it to a brick along with a note clearly explaining my opinion on his competancy and I'll throw it through his window.
To illistrate(JIC = AN)
Page generated in 0.15107 seconds with 11 queries
