Old 09-20-2008, 07:10 PM   #1 (permalink)
Kason23's Avatar
Member Number: 34502
Default Return line question!
So Im running 650s on a 44lb delta kit I have plenty of fuel at 22psi till about 5K then im almost out.. My question is im fixing to order a agp return line and prob run a 1:1 and turn my fuel pressure down to help with idle and crusing. I dont know much about return lines and wanna know if Thats right or what. thanks in advance!
AGP DELTA 46/DSP/Coolingmist Meth Addict
432whp/425wtq (25psi) on pump and meth
Tuned By TDSAaron!!
Old 09-21-2008, 10:42 AM   #2 (permalink)
SRT of the Month
bitts's Avatar
Member Number: 29842
Trader Rating: (113)
Yea man your running static psi, a return line would be in need.
You would need a rail with a fitting on the end of it to hook up the FPR, then you can drop the the fuel pressure.
Theres a thead uncommon has on how to make your own.
Borg Warner S256 JJ&B
Quote: Originally Posted by kylejoseph426 View Post
yes the pcm has been reset everytime. yes the timing is set perfect we used the Bitts cam tool
bitts is offline   Reply With Quote
Old 09-21-2008, 09:30 PM   #3 (permalink)
Kason23's Avatar
Im just gonna get AGPs kit so I can use my stock rail sound good? I figure a lower pressure will make my drivability good again
Old 09-22-2008, 09:39 AM   #4 (permalink)
SRT of the Month
bitts's Avatar
AGP's kit goes b4 the rail as far as I know, mine fpr is after the rail.
