Old 09-01-2006, 09:11 AM   #1 (permalink)
nme
nme's Avatar
Member Number: 42393
Default Which Return line kit?
I am going to be shooting for 300hpish area with wga, map clamp, return line, exhaust, fmic,. Which return line kit is the best for me? Im looking to do this on the cheap so can you guys reccomend a good cheap kit that will work for me?
nme is offline   Reply With Quote
Old 09-01-2006, 09:14 AM   #2 (permalink)
2005 Orange-Blast's Avatar
Member Number: 33789
aaroneon or agp....
Before:
After:
Now:
2005 Orange-Blast is offline   Reply With Quote
Old 09-01-2006, 07:55 PM   #3 (permalink)
Member Number: 30133
I seem to see alot more positive things from aaronneon then pretty much anyone elses.
THE BUDGET TURBO GODFATHER!
Hello my name is Jason.....and I drive a Nissan Pick-up
jasonsrt4 is offline   Reply With Quote
Old 09-03-2006, 09:53 PM   #4 (permalink)
Lil Buddy's Avatar
Member Number: 38010
Trader Rating: (39)
both aarons and agps are good units, but with aarons you need an 03 fuel rail or an aftermarket fuel rail with a schrader valve on the end of it, aarons is a little more expensive but it is installed after the fuel rail instead of before the rail which is the way it should be
First E1 turbo in the 11's(11.95@119 mph)
First E3 in the 11's (11.39@124 mph and 11.54@127 mph )
Also known as Brad@RealTune
Lil Buddy is offline   Reply With Quote
Old 09-04-2006, 06:16 AM   #5 (permalink)
Nathan's Avatar
Member Number: 11386
UOTE=whitesrt05]both aarons and agps are good units, but with aarons you need an 03 fuel rail or an aftermarket fuel rail with a schrader valve on the end of it, aarons is a little more expensive but it is installed after the fuel rail instead of before the rail which is the way it should be[/quote]
So how does the AGP work if it is installed wrong?
Nathan is offline   Reply With Quote
Old 09-04-2006, 10:37 PM   #6 (permalink)
Member Number: 10209
So how does the AGP work if it is installed wrong?[/quote]
it's not wrong persay, but MOST return systems are regulated after the rail. But AGP developed theirs with 04's and 05's in mind regulating hte fuel before the rail. both get the job done.
-AGP-Blitz-ClutchMasters-Engine Run up-E.D.-JLM-HKS-Hotchkis-MSD-Turbo XS-Walbro-
mark2685 is offline   Reply With Quote
Old 09-05-2006, 09:48 AM   #7 (permalink)
Lil Buddy's Avatar
Trader Rating: (39)
yea i never said it was wrong, b/c it does work
Old 09-05-2006, 04:42 PM   #8 (permalink)
Member Number: 17858
Get the aaronnneon kit. The design is better IMO because it regulates the fuel after the rail and the FPR is in a much better spot because of that. Both will get the job done, but for a little extra the aaronneon is worth it.
Grifter is offline   Reply With Quote
