Question on tuning with SAFC&Returnline
First off my mods are as follows.
BW S256 .55 ar
FIC 725cc injectors
Realtune return line
SafcII
55mm TB
Ported Intake mani
Ebay 4" Intercooler
Snow performance Meth kit (100% meth)
TurboXS High performance boost controller
3" Exhaust
Crane 12 Cams
And i think thats all that will be relevant to this issue.
So my problem right now is i am pulling too much fuel on my safc and i dont want to cause knock and blow my motor. I have tried two ways:
1. I have set my FP at 35psi and then put a boost source on the regulator and tuned it to 24psi with the meth, i still end up pulling like 24-28% across the whole rpm range.
2.(also tuned to 24psi with meth) I set my FP to 58psi static and i end up pulling 28% up to 4000rpm then after that it goes like 4600/13%, 5200/3%, 5800/0%, 6400/0%. Even tuned like this at WOT i am real rich down low and up top around 11.9-12.1 (okay on meth)
Im trying to find a way to not pull so much fuel and i really dont see how. I dont have a bottleneck mod, but i dont know if that would enable me to lower the fuel pressure enough to where i could pull a lot less. Any thoughts??? Thanks!
HATED............
