Old 10-20-2009, 01:55 PM   #1 (permalink)
Member Number: 70890
Default Poor gas mileage. 1/2 a tank in 50 miles
So I had misfire in cylinder 3... didn't use a lot of gas... plug was snow white. lol. so replace all the injectors, new plugs, new intake manifold gasket, and new injector o rings.. ever since i did this car will go through about half a tank in 50 miles... i know i need tune with my mods, but sure seems like something else is at work here... any ideas?
thank you as always.
2005 DODGE NEON SRT-4
MPX FMIC, 62MM MPX TB, AGP WGA, K&N CAI, AGP HARD PIPE, TURBOXS -RFL BOV, STAGE ONE INJECTORS, HAHN MANUAL BOOST CONTROLLER, 3" MPX SINGLE EXIT EXHAUST WITH NO CAT AND 3" O2 HOUSING, FUEL PUMP RE-WIRE MOD, BATTERY IN TRUNK.
HUB SRT is offline   Reply With Quote
Old 10-20-2009, 03:05 PM   #2 (permalink)
AngrySrt's Avatar
Member Number: 71255
Trader Rating: (20)
smell any gas? check the lines and when you turn the car off is the line still primed? when you pull off the fuel lines it should spray, i have an 03 and i can just poke the bleeder to see if there is any pressure, turn the car on to prime the fuel pump and see if it has pressure..
2003 srt-4 stage 1 pcm, DSP tuned by john at ptp, stage 2 injectors, agp wastegate with ptp spring mod,agp full race bfmic, agp intake, areoforce scan guage, mpx extrude honed mani,mpx 62 mm throttle body, cti charge pipe,agp up pipe with hks bov, aem wideband, 3 inch side exit, hold 17.
Jon at PTP is the shiznit!!!!!
AngrySrt is online now   Reply With Quote
Old 10-20-2009, 03:21 PM   #3 (permalink)
I primed the line before starting it when I did the job... The bleeder is located between cylinders 2 and 3 on the fuel rail? Should press the bleed when the car is running? And if it turns out I have no pressure... Guess? Fuel pump?
Old 10-20-2009, 03:30 PM   #4 (permalink)
AngrySrt's Avatar
Trader Rating: (20)
ummm did you reset the pcm when u changed the injectors???
Old 10-20-2009, 03:34 PM   #5 (permalink)
Its was the same kind of injectors... Figured I didn't need to... I cleared the code for misfire before I did the injectors.
Old 10-20-2009, 03:48 PM   #6 (permalink)
AngrySrt's Avatar
Trader Rating: (20)
well if you reset the code it might just be relearning the fuel trims, fill her up and drive around and if it happens again then more trouble shooting, and i only get 100 miles per half a tank so im not to far off from ya
Old 10-20-2009, 04:02 PM   #7 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
You have a serious problem or a leak somewhere. It's not re-learning the fuel trims. Good god :facepalm:
It's going to be kind of hard to find the leak on account of the gas drying up...shit. Maybe jack it up and start it, see if you can find the leak along the lines.
or 16 whatev
WTB: LCA bushings
Adionik is online now   Reply With Quote
Old 10-20-2009, 04:10 PM   #8 (permalink)
I didn't smell any gas... Only disconnected by the fuel rail... And I would know fast is gas was leaking over the engine. Lol. Ill reset the ecu, check for pressure and check for leaks. But if I do all that and strike out, don't know what next...
Old 10-20-2009, 04:34 PM   #9 (permalink)
Adionik's Avatar
Trader Rating: (25)
You might not smell it if it's leaking at the canister or FPR area
Old 10-20-2009, 04:37 PM   #10 (permalink)
I would smell gas by there is it was... Well will wait till I get my car back from the shop and keep you all posted... Thanks everyone for your help!
Old 10-20-2009, 04:54 PM   #11 (permalink)
boneriffic's Avatar
Member Number: 60776
o2 sensors?
Fothermucker.
boneriffic is offline   Reply With Quote
Old 10-20-2009, 04:58 PM   #12 (permalink)
Replace the 02 sensor when I put the new exhaust... Has not cat and get the 0420... I know gas will be down due to mods, but still should be seeing about 200 a tank... About...
Old 10-23-2009, 11:29 AM   #13 (permalink)
is there any way to bleed the line with a 05 stock fuel rail?
Also would the fuel pump re wire mod be causing this?
Old 10-23-2009, 12:19 PM   #14 (permalink)
morgantj13's Avatar
Member Number: 47175
Why do you want to bleed the fuel system/rail?
How long ago did you do the fuel pump re-wire?
Old 10-23-2009, 12:24 PM   #15 (permalink)
Before I put in the new injectors in... Maybe a about a month...
Page generated in 0.18480 seconds with 13 queries
