View Poll Results: Fuel Pressure Drops to 0 after shutdown??
Fuel Pressure drop to 0 rights away after shutdown. 7 87.50%
Had a problem, but now I fixed it!! 0 0%
Never had a problem. 1 12.50%
Voters: 8. You may not vote on this poll
Old 07-18-2008, 11:51 PM   #1 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Default Poll: Fuel Pressure drop when turning off motor
Im one of many with fuel pressur problems and wanna get it squared away. Just curious how many are out there with the same problem.
Also, if you fixed your problem, what did you do??
I tried the "pushing the FPR in" but it did nothing for me.
I ordered a PTP O-ring 3 weeks ago but he gave me a refund for me complaining that I never got it 2+ weeks later.
Just want some input on whatelsle to check. I tightened down ALL connection on my Returnline. I built it myself, Could I have not installed the SS line into the fitting all the way???
FS: HID Fogs Kit - 6000K & 3000K(Yellow) - PM Me
Performance Mods: AGP S3D 48lb - Returnline - Mopar Stage 2 w/o Toys - DW 650cc - TurboXS HPMBC - Maddog STS - MaxxFab 3" DP w/o Cat Magnaflow Muffler - AIS Intercooler - ED LPP - ED UPP w/ HKS BOV - Injen Intake - NGK V-Powers @ .032 - FBM Ported Intake Mani/Spacer - DCR 55mm Throttle Body - DCR Oil Mod - Devils Own MethInjection, M5 - DTEC - AEM UEGO
385HP and 385TQ
Gmanigio is offline   Reply With Quote
Old 07-18-2008, 11:52 PM   #2 (permalink)
bpsrt4's Avatar
Member Number: 40796
Trader Rating: (27)
I think it would be leaking if that was the case
But, I have no idea about what my fuel pressure did after i shut the car off when I had an AGP returnline, I have converted the AGP to be after the rail (just waiting on a fuel rail) So I guess I'll have to get back to this thread
bpsrt4 is online now   Reply With Quote
Old 07-18-2008, 11:55 PM   #3 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
I built it last summer, and pushed the SS line ALL the way in as far as possible.
The stock FPR moves around some, so that may be the culprit. Just wondering what others have done.
Old 07-19-2008, 01:55 AM   #4 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
Trader Rating: (18)
I never had a problem with mine at first (built it myself) it would take roughly 1 1/2-2 hours for it to drop completely to zero. Then all of a sudden out of the blue it's now dropping down instantly. I had a leak in my fuel line (the return side was rubbing against the trans and wore a hole in my SS braided line) and I eventually got that fixed but it still drops instantly. Doesn't really bother me a whole lot since I have a push button starter on the car. By the time I turn the ignition on then reach down and push the button the car is already primed so I don't have to sit there and crank it like crazy.
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is offline   Reply With Quote
Old 07-19-2008, 10:35 AM   #5 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
BUt will that affect overall performance??
I was at he dyno, at 48psi then seeing 23psi of boost. That should be 71psi on the FPR gauge. But the most I saw at WOT full boost was 60-62psi, and I thought it was because of a leak, and the leak was part of dropping to 0 part.
My line is also sitting on the transmission, I should check it again, but last I checked it was ok. I should buy a 90* fitting for that
Old 07-19-2008, 03:11 PM   #6 (permalink)
Trader Rating: (18)
I have no 1:1 hooked up because it was too hard to tune for me. Felt like I was gonna wash out the cylinders or pull 20 degrees of timing trying to get the fuel down lol. With my 57 trim and 650 injectors my pressure is only 47-50psi boosting 21psi and ending up with an 11.5-11.8afr so I really can't complain with how the car's running and there were no performance issues at all once the fuel started dropping when the car was shut off.
Old 07-19-2008, 06:29 PM   #7 (permalink)
bpsrt4's Avatar
Trader Rating: (27)
The aeromotive fpr won't go over 70psi I believe
Old 07-19-2008, 06:47 PM   #8 (permalink)
riceisnice's Avatar
Member Number: 20625
Trader Rating: (12)
Mine leaked down really fast after I turned it off too. I just replaced the o-ring with a slightly bigger one and it fixed the problem.
riceisnice is offline   Reply With Quote
Old 07-19-2008, 07:16 PM   #9 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
I just placed an order for 4 oversized o-ring, dont know which size I need so I ordered 4 diff. sizes. Hope it helps....
Old 07-19-2008, 07:17 PM   #10 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Yea, 70 or 75, dont remember.
But I will only hit 60-62, so its still not hitting max FP @ WOT
Old 07-21-2008, 12:22 PM   #11 (permalink)
roadflare16's Avatar
Member Number: 41558
Trader Rating: (20)
wait, replaced the o-ring for what, the factory fpr? i just replaced my fuel pump, again, since the walbro I had died after about 100 miles, and that big rubber o-ring for the fpr had easily grown to twice it's normal size and wouldn't go back on, so I had to cut about 2in out of it, and it was still overlapping itself a good inch, but before that it held pressure beautifully, now it drops down to 20psi immediately and then slowly drops from there. anybody know where to get a replacement o-ring for that?
roadflare16 is offline   Reply With Quote
Old 07-21-2008, 10:51 PM   #12 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Your talking about the spongy thing?? That ussually went back to normal size after the gas dries up.
Atleast you hold 20psi
Page generated in 0.37978 seconds with 12 queries
