Old 01-01-2009, 12:37 PM   #1 (permalink)
Member Number: 42356
Default Octane Levels
Hey guys I was wondering what octane I should run. My mods are in my sig. I have a race gas tune from Rage Tek and I used a 101 octane from sonoco and there was a pretty big difference. I was wondering would I get more power if I ran a 110 leaded and would that hurt my wideband. Also I have the predator to tune with. Also I keep hearing about C16 race gas, what is that?
Mods: Maddog STS w/bushings, Solid MM, PTP WGA (20PSI) , CAI, 3" Downpipe, 3" Custom Side Exit Exhaust, Stage1, AGP Fuel Return Kit, BFMIC, Hot and Coldside piping, Turbonetics BOV, Perrin BOP, Rage-Tek Custom Tune.
13.3 1/4 on street tires
jthomas123 is offline   Reply With Quote
Old 01-02-2009, 11:22 AM   #2 (permalink)
Member Number: 18856
yes leaded will mess up your wideband. not at first but latter on down the road i learned this the hard way luckily i had an extra one.
C16 Used in turbocharged engines, blown engines and nitrous applications with CRs up to 17:1. Recommended by the top nitrous oxide companies. Spec Fuel for NHRA Comp Eliminator.
Color: Blue.
Motor Octane: 117.
Specific gravity: .735 at 60° F
not a thing just another slow a$$ neon
joe smalls is offline   Reply With Quote
Old 01-03-2009, 02:59 PM   #3 (permalink)
brianbr's Avatar
Member Number: 50755
if you are not pulling timing or getting any knock with the 101 there really is no need to run more octane.
F&F ported ex manifold, ptp wga, 3" O2 housing and downpipe, custom 3" dump, pump rewire, 255 pump, S2 injectors, Dtec, BC stage 3 cams, fidanza gears, ported throttle body, aem cai. agp solid mounts and race fmic, ultimate racing uhp, Hks ssqv, aem wideband, aeroforce scanguage. Hotchkis springs, Prothane Lca's
brianbr is offline   Reply With Quote
Old 01-12-2009, 08:29 AM   #4 (permalink)
Member Number: 30696
if your going to spend the money on C16, go find some Q16. better on boosted motors.
amdguy is offline   Reply With Quote
Old 01-12-2009, 03:02 PM   #5 (permalink)
2004NeonSRT4's Avatar
Member Number: 4577
Trader Rating: (44)
run what ever was in the car when it was tuned for that fuel. or get a retune with the new selected fuel.
2004NeonSRT4 is offline   Reply With Quote
Old 01-12-2009, 05:24 PM   #6 (permalink)
ReDsRtKiD's Avatar
Member Number: 46248
Says who?
New Set-up comin' soon..
6/11/08-5/07/09 91pumpking
ReDsRtKiD is offline   Reply With Quote
Old 01-13-2009, 04:49 AM   #7 (permalink)
Quote: Originally Posted by ReDsRtKiD View Post
Says who?
google it. or clicky these links...
VP RACING FUELS - LEADED FUELS
or i will quote...
"Q16 will work well in any drag racing or circle track application -- naturally aspirated, nitrous or blowers. Q16 is highly oxygenated, requiring a 4-6% increase in fuel flow, which will make 3-5% more power than competitive 116 octane fuels. Q16's oxygenation will significantly expand the range of air/fuel ratio acceptability, so performance will be more consistent and won't vary as dramatically with altitude or density changes. For bracket racers, variations in ET from run to run will be substantially reduced. This added fuel flow also effectively increases its octane by 6-8 numbers above its standard ASTM octane rating."
when you switch from C16 to Q16
independent tests
Q16 vs. C16 - ModularFords.com
q16 vs c16 main. question - Yellow Bullet Forums
(place where ALOT of 10.5 outlaw guys hang out, and ALOT of the pumpgas drag cars hang out)
Old 01-13-2009, 10:46 AM   #8 (permalink)
brianbr's Avatar
Yes q16 is good for boosted motors, but it would be a waste for the op to go spend that kind of money on fuel that he wont be able to take advantage of. he is limited to how much boost he can run (because of the stock turbo) with the dsp you can advance timing to what degree, i dont know. you can max the stock turbo out with what he has, using 110. also 110 is about half the price of q16
Old 01-13-2009, 11:01 AM   #9 (permalink)
well i do agree it is a waste, but if he is going to put C16 into it, might as well do Q16, costs the same (atleast where im at it does)
Old 01-13-2009, 11:51 AM   #10 (permalink)
Slow_spool's Avatar
Member Number: 50382
Trader Rating: (33)
i reccomend to run what ever gas the car was tuned on and tuned for..
running a higher octane does give you a larger room for "error" as i like to say.
c16 and q16 are both good for turbo applications.
q16 is more oxeginated then c16, and may require a little bit more fuel then c16.
Slow_spool is offline   Reply With Quote
Old 01-15-2009, 10:19 PM   #11 (permalink)
JiM P 2001's Avatar
Member Number: 40408
On my current setup I run C12 when I'm at the track. Leaded fuel will damage your oxygen sensors. I have not run into an issue because I don't run it often. I run 93 pump in the street. Next year I'm spraying and having the car tuned for C16. Still running 93 pump for the street because I will not have the bottle in the car unless I'm at the track.
Black 2004 Dodge Neon SRT-4
Hotchkis Springs & Swaybars
S2 w/ Toys, AEM CAI, MPx FMIC, AGP WGA, Full Stock TBE, Gutted Cat, 22psi, VP C12 Fuel
On Streets, Off Spray: 12.80@114 2.2 60'
On Slicks, Off Spray: 12.24@112 1.74 60'
JiM P 2001 is offline   Reply With Quote
Page generated in 0.18739 seconds with 13 queries
