Mpg? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-13-2012, 05:53 AM   #1 (permalink)
Teerav's Avatar
Member Number: 90805
Default Mpg?
Ok so I got what was soposed to be a stock srt. Ain't stock soposed to get around 24mpg . I'm getting a average of 20. Is that normal I drive it normal most of the time change gears about 2.5rpm dose bigger injectors always spit more fuel or just under WOT thanks for any words of wisdom o and air filter is clean its a aem short ram
Teerav is offline   Reply With Quote
Old 11-13-2012, 06:01 AM   #2 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Check basic maintenance first (like new plugs wires, pcv, air filter, fuel filter, etc). Also do a boost leak test to verify you have no vacuum or boost leaks. Another common issue with bad MPG in the neon is a bad upper O2 sensor.
You say you drive it normal most of the time. Well if you are doing some wot pulls, thats going to kill your average mileage.
Do you have bigger injectors?
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 11-13-2012, 05:31 PM   #3 (permalink)
Member Number: 16678
depends how you drive. if you drive in boost your mpg will be dramatically lower. ive ranged from 11 to upwards of 25-28 mpg. im stock. 20 mpg sounds right to me.
JussBL4ZE is offline   Reply With Quote
Old 11-13-2012, 07:12 PM   #4 (permalink)
Teerav's Avatar
Not sure the bottom of the injectors is blue? I run 93oct and don't have a check engine light not sure if it will show if the o2 is bad.
Old 11-13-2012, 07:17 PM   #5 (permalink)
Teerav's Avatar
And I don't have a compreser to do the boost leak test. And not a 100% sure even how to lol but I will do the plugs and probly do bigger wires wile I'm at it. Is there a sound I should here or will the leak show on the boost gage or will it idle funny do to leak idk I'm used to NA cars
Old 11-13-2012, 07:23 PM   #6 (permalink)
SRTFORUM Moderator
Advans's Avatar
Member Number: 12791
Sounds like you need to do a lot of researching..Use the Search feature at the top of the page, it'll help ya a lot.
Advans is offline   Reply With Quote
Old 11-13-2012, 07:33 PM   #7 (permalink)
Dont rely on a CEL to figure out an issue.
Just because there is no CEL doesnt mean the O2 sensor cant be bad.
310HP 436TQ
XXXHP XXXTQ
Old 11-13-2012, 07:37 PM   #8 (permalink)
jay05acr's Avatar
Member Number: 37744
^this
And find a local Srt guru who is willing to help out, good luck
Go to wikyd-performance.com for all of your srt4 performance needs. Contact jtm0n3y or wonderer86 for more info
http://www.srtforums.com/forums/f416...-parts-639326/ my for sale thread
jay05acr is offline   Reply With Quote
Old 11-13-2012, 07:58 PM   #9 (permalink)
Teerav's Avatar
Ok thanks you guys
Old 11-13-2012, 08:05 PM   #10 (permalink)
Cor430vette's Avatar
Member Number: 78320
After you do all this crap then check it...
SRT-4 Performance Modifications and Upgrade Paths
Also I did a boost leak summary in my sig links...check it out..
The mind creates a false mind-made self that casts a shadow of fear and suffering... 2008 black Corvette / 2004 black SRT4 Owned 2004 and 2005 SRT4 both sold...this is my 3rd friggin one...what the fugs wrong with me??
http://www.srtforums.com/forums/f169...l-help-634159/
http://www.srtforums.com/forums/f75/...w-pics-630960/
http://www.srtforums.com/forums/f25/...ummary-569367/
Cor430vette is offline   Reply With Quote
Old 11-13-2012, 08:07 PM   #11 (permalink)
Teerav's Avatar
And Thia stupid phone won't let me use the search idk why and I don't have a PC so I'm stuck lol trust me I don't like making posts about little things like this I'd rather search and find it my self
Old 11-24-2012, 12:13 PM   #12 (permalink)
mattewhite04's Avatar
Member Number: 76009
i get 20/25 on 91 fully built. e85 is like 14-16/20
BW255 .48ar 28psi, 100% E85
full bolt-ons,
built motor/CNC head
mattewhite04 is offline   Reply With Quote
Old 11-24-2012, 12:29 PM   #13 (permalink)
Member Number: 87423
I've had a vacuum leak recently and yes you will be able to see it on the boost gauge unless it is minuscule. I run about 22 to 23 in. Hg. At idle. Mine was showing 15 with the leak. Also you can smoke the intake. Just make sure all obvious exits are blocked ex. Air filter, valve cover breather, ect.
kevin1533 is offline   Reply With Quote
Old 11-24-2012, 01:41 PM   #14 (permalink)
617srt's Avatar
Member Number: 89718
i average 17 mpg not going into wot once so you should be happy with 20.
617srt is offline   Reply With Quote
Old 11-24-2012, 09:52 PM   #15 (permalink)
lilviper's Avatar
Member Number: 5474
I get about 14-20 in town.. on the highway its about 25.. unless you push the fun button hehehe then it stays low.
lilviper is offline   Reply With Quote
