Old 01-09-2006, 12:03 PM   #1 (permalink)
Member Number: 29473
Default Misfiring and Lights Flickering
Hey, recently my car began running extremely rough and inconsistent, and at low RPMs it bucks and surges not running smooth. Also I've started noticing that my dash lights and headlights flicker for about 5 minutes after I start my car and begin driving. If I drive faster the flickering gets worse, if I turn the lights off for about 5 minutes while the car is running and turn it on again, it will usually work. I have replaced the ignition wires and tomorrow I'm putting in new spark plugs. Do you think the flickering and misfiring are related? I'm going to take a look at the TPS also after the plug but I don't know if it would fix the guage lights. Thanks for your time.
'90 300ZX - For sunny days =)
'03 SRT-4 - AGP WGA, MBC @ 18psi, Mopar BOV, MSD 8.5 Plug Wires, 2004 Injectors, Short Shifter, 30psi Boost Gauge, A/F Gauge, Carbon Fiber Hood (Came with), HIDs, Huge Intercooler, Mopar Exhaust, CAI, Blue Gauges, probably more...
mick006 is offline   Reply With Quote
Old 01-09-2006, 12:15 PM   #2 (permalink)
acancelledczech's Avatar
Member Number: 35576
sounds like the coil is going bad
Sony A700 ~ SRT-less
acancelledczech is offline   Reply With Quote
Old 01-09-2006, 01:07 PM   #3 (permalink)
srtkid's Avatar
Member Number: 1956
Trader Rating: (13)
my lights slightly flicker...but i have cams/cam gears
srtkid - doin 40mph rolls in 2nd gear since 6/03
Mods
2.5L SRT-4
S0 DW S2 injectors
JE Pistons 8.5:1 (.040 ob)
Eagle Rods
Race Ported/Polished Rev Valved Head
BC Stage 3 cams
Fidanza CG
Race Ported Exhaust Manifold w/external wg
FM E1 with port/polish
DCR Oil Modifier
Walbro Fuel Pump, Fuel Return Kit, map clamp
CAI, QW FMIC, 60mm TB, 3"TBE w/cutout
srtkid is offline   Reply With Quote
Old 01-09-2006, 03:14 PM   #4 (permalink)
Member Number: 29032
Check your grounds.
Check to make sure that the negative side of the battery is connected solid. Also there is a grounding strap close to the PCM (on the top radiator support) that connects the harness to chassis ground... make sure that is also on solid.
'04 SRT-4
11.66 @ 119.3
WhatsADSM is offline   Reply With Quote
Old 01-11-2006, 09:29 AM   #5 (permalink)
Can someone tell me where the TPS harness connects to after coming out of the throttle body? I'm going to check the grounds tonight and look into a new coil. Thanks
