Let me start off by saying my car runs and drives fine, and holds HOM just fine. I am more confused than anything. I know the stock 2nd gen neon / srt fuel pressure regulator is 58 psi. I was under the impression that the stage 3 comes with a regulator that is higher, maybe 75 psi?
Well, I am getting ready to do my nitrous jetting, so I hooked up a fuel pressure tester to my fuel rail, to see what the fuel pressure is. I primed it a few times, and checked it and it was reading around 60 - 64 psi. Then when I fired it up, it was bouncing between 49 ad 50 as it idled. This immediatly confused me.
I called my buddy over to watch it when I gave it a little bit of gas. I reved it in neutral to 2500, and then to 3000 and he said the pressure dropped down to 45 - 48 psi. This doesn't seem good, it should at least be holding 58 psi, right?
I have stock fuel lines, a walbro 255, stage 3 rail and injectors.
What should my fuel pressure be on a stage 3? Any clue why its dropping when I give it gas?
--mark
'03 SRT4 - 11.930 @ 119.68 - first pass with the new slicks --My Mod List--
truth is, that's 100% normal. You'll find that sometimes it may even drop to 40-45psi. The pressure should jump instantly with a flick of the throttle to 55-60psi, even in idle. I've seen my pressure go as high as 80psi under 25+lbs of boost.
Stg3 toys, ported head & intake, NX 4nozzle, progresser, wide ban, egt, fuel pressure, injen, samco, Mpx3", Maxxfab02,Greddy CC, Boomba's, AIS intercooler, STS, billet SS, .020 8-1 JE's, Eagle 4340 H beam rods, UDP, you name it I've done it Mopar Clutch
Honestly, when I jetted my kit it was for fuel pressure in the 60-75 range. There for, you should be alittle leaner on the fuel jetting then what they ask for. for example
I'll see if I can track those ones down. If not, it should be OK, but I don't want to risk the motor, I am already making some pretty decent power, as you can see by my trap speed.
You may know, since you seem pretty knowledgeable on this stuff. When I spray, the fuel solenoid is goign to open, and take some of the fuel from the rail (duh, thats how it works ) Will this affect my fuel pressure, in essence having the fuel injectors get less fuel, or will it just work? I figure the regulator will catch any drop in pressure, and make it right.
