I have everything else that I need for my FP Green setup, with the exception of injectors. I am pretty set on picking up a set of DW 650's but know that I could possibly have some issues with running lean up top. I am just going to use a S2 pcm, 255 pump, Neo, and larger injector combo. I will just be running 93 octane pump gas and shooting for somewhere around 20-22 psi. Is there anything in between the 650' and 725's that I could run without a returnline and not have idling issues etc.? Or should I just stick to 650's?
I figured I would eventually need more things besides just injectors, but just want to keep it simple for now. I guess I could just start with 650's now and get what I can get out of them, then upgrade more later. The 725's sounded sweet, but I think that will be too much fuel to pull out down low. I am just looking to do 360-370 on pump gas right now so hopefully just the 650's and 255 will get me in the neighborhood... maybe?
Have any of you guys done the fuel pump rewire? I was thinking of adding that to help up top possibly, but I am a little hesitant to add something that connects to my alternator.
Never did it, and could care less to be honest. I have the 255, my own bottleneck fix, stock feed line, built my own "03 fuel rail" and built my own fuel returnline and the system works just fine on a 50 trim as well as a 57 trim both making mid 20's psi with zero issues.
