Old 08-17-2009, 01:07 PM   #31 (permalink)
nutz's Avatar
Member Number: 41700
Quote: Originally Posted by chuck's_srt-4 View Post
Here you guys go:
Bosch Fuel Pump Pre-filter Fuel Sock For 044 [BFP-PF1] - $50.00 : Jay Racing
The price is a little steep, but, well...you guys know the saying!
perfect
JDP
Dynomite tuning
Old 08-17-2009, 01:17 PM   #32 (permalink)
boots's Avatar
Member Number: 67116
Heres the thread where the 044 was used intake and with an inline. The guy is also on E85 so I think the pump should be fine. Bosh 044 in tank, to bosh 044 inline with pics.
2004 stage 2-AEM ems-DCR intake manifold-crane 16's(stock valve train)-DCR automatic setup-dss axles-boomba fuel rail-boomba mounts-boomba throttle body-3in side exit exhaust- spearco intercooler- Borg Warner S360RS and PFI/Kevin Warren tubular manifold setup
Soon to come, my high compression build New turbo setup and transmission setup
boots is offline   Reply With Quote
Old 08-17-2009, 01:41 PM   #33 (permalink)
Member Number: 4648
i found this site that carries the filter
Pegasus - Fuel Safe ASA 5700 Sock Filter
JnR
Chase for 10's in norcal is on
for DSP NEEDS PM only: Turbo66, Mindmelt,
reed32 is offline   Reply With Quote
Old 08-17-2009, 01:45 PM   #34 (permalink)
NoisufnoC's Avatar
Member Number: 136
its also my understanding that the 044 performs better at higher fuel pressures than the wally 255. especially helpful if you run 1:1 rising rate fuel pressure.
I remember the days of...
...most of you weren't born yet.
|| Mod List || (Re)Build Thread ||
Old 08-17-2009, 01:51 PM   #35 (permalink)
Member Number: 4648
thats correct. from my readings on other forums, the bosch pump isn't much louder than the wally 255 pump in the tank.
JnR
Old 08-17-2009, 01:52 PM   #36 (permalink)
boots's Avatar
I just looked, I think its $18 for the filter and $30 for the adapter to make it work on the 044. So really it's about the same price.
Old 08-17-2009, 01:53 PM   #37 (permalink)
Member Number: 4648
yeah it is
JnR
Old 08-17-2009, 01:58 PM   #38 (permalink)
boots's Avatar
I was hoping I was wrong
yeah it is
Old 08-17-2009, 02:04 PM   #39 (permalink)
nutz's Avatar
think i would be OK with stock fuel line, i think its comparable to -6 line
JDP
Dynomite tuning
Old 08-17-2009, 02:05 PM   #40 (permalink)
Member Number: 4648
you have to upgrade your fuel line
JnR
Old 08-17-2009, 02:12 PM   #41 (permalink)
boots's Avatar
I would go ahead and do atleast a 8n or 10n for feed and I'm doing a 6n for my return. But I'm doing E85, so i want to flow a lot more volume. I might do a walbro feeding the 044 pump, may put a 1-2 gallon in between them not sure.
Old 08-17-2009, 03:09 PM   #42 (permalink)
nutz's Avatar
OK, well my regulator is only -6, and i'm being cheap. i dont think i will see over 600 (dont need to)..seeing as mid 4's scared the life outa me. but then again the 35r comes on very slow a gentile
JDP
Dynomite tuning
Old 08-17-2009, 03:29 PM   #43 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
The bosch 044 is very potent at high pressures! It's max pressure rating is 150 psi.
If you want a pump that is specifically designed for high pressure systems, the Bosch 413 pump is rated at >200 LPH @ 8 BAR.
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
Old 08-17-2009, 03:47 PM   #44 (permalink)
NachO_SRT's Avatar
Member Number: 8662
Just found this thread.
My current fuel set up, 044 in tank, -8 feed to 044 inline -8 feed to rail, -8 to magnafuel regulator (70 psi base 1:1 Boost/vac refrenced RR).
Flows just over 610lph. 150ish Gal/hour. It'll empty my tank in a couple of mins. With no head pressure.
I did get the jays racing fuel sock, it's a way better filter. This also eliminated the need for my old pre filter, 74 micron magnafuel.
The 044 is in tank, and it is ok so far. I may go back and conformal coat the connectors but none of the research I did lead me to belive that there was any danger of "spark" or fire. The only danger I found was the ability for E85 to work it's way into the inner housing through the electrical connectors and eat away the insulation, this may cause a ground fault condition.
All the damn info is written in Chezk or German, hard as balls to translate and not laugh...or fall asleep.
more pics can be found at NachO_SRT mkcperformance.com Blog
And the 044 info can be found on the main blog page: BOSCH 044 Fuel Pumps, now available mkcperformance.com Blog
Some good info in there.
If you have any questions or need any info on the 044, just ask. I'm running a full boost rail pressure of 100psi. ID 1000's are flowing 1525CC @ 100psi.
NachO
DD -09 STi | Track Car. 2004 E-blue; Mods and pics: CLICK
S259@ 25psi:614/567 -6/10, E85 - Meanblueberry.
NachO_SRT is offline   Reply With Quote
Old 08-17-2009, 04:04 PM   #45 (permalink)
NachO_SRT's Avatar
Member Number: 8662
Bosh 044 Vs Walbro 255 LPH.
NachO
