Old 03-06-2009, 12:49 PM   #1 (permalink)
GreddyHovs's Avatar
Member Number: 62333
Default Installed walbro pump and return line. Now, ZERO fuel pressure.
I'm finnaly stumped. Installed a Walbro 255 fuel pump and setup up JMB's return line it. For the return line, I just drilled a hole in the canister lid and stuck the correct fitting there. It's not completely tight but it is tight. First, I tried starting the car and no go. Realised I forgot to waterweld the stock FPR. Did that and still nothing. I have a fuel pressure gauge on my boomba fuel rail and it's showing 0psi. My regulator is attached to my rail. I cant think of what the problem might be. I have 1/2 tank of fuel now which is why i'm not looking forward of lowering the tank again.
-- GT3076R, 750cc Injectors, Walbro Fuel Pump, Boomba Fuel Rail, JMB Fuel Return Line, SCT tune, 3" Catless Mpx Turbo Back Exhaust, Mpx FMIC, Clutch Masters FX400, Megan Racing Coilovers, AGP Motor Mounts, HKS SSQV, AEM UEGO, Phantom II Gauges, Interceptor Scan Gauge
GreddyHovs is offline   Reply With Quote
Old 03-06-2009, 03:06 PM   #2 (permalink)
Member Number: 36666
Sound like it could be electrical. Did you put the wires back right in the connector and connect the ground back up?
bfgracing is offline   Reply With Quote
Old 03-06-2009, 05:15 PM   #3 (permalink)
GreddyHovs's Avatar
I had the pink and thick black line's backword's. Everything is good now.
