10-31-2009, 08:20 AM
#1 (permalink )
Member Number: 13792
Injector Dynamics 1000CC's
who has these and who has the best price? btw can a bosh 044 be had for less than $185?
AGP hot and cold ic pipes, Needswings v6 dp, mccord plate, Auto meter EGT and wide band, Magnaflow ext,BFMIC,AGP dog bones and trans mount, AGP wast gate,S1, WOT box, DSP.
10-31-2009, 10:09 AM
#2 (permalink )
Member Number: 67116
T1 racing is the only place I can think of that has the ID's
2004 stage 2-AEM ems-DCR intake manifold-crane 16's(stock valve train)-act clutch-dss axles-boomba fuel rail-boomba mounts-boomba throtle body-3in side exit exhaust- maddog 58 STS-built trans( Rage accelerator, Rage 3/4 fork, and p-werks selector)- GT3076R
Soon to come, my high compression build
New turbo setup and transmission setup
10-31-2009, 11:49 AM
#3 (permalink )
Member Number: 12457
appearently FIC 900's are the same injector....according to realtune
10-31-2009, 02:20 PM
#4 (permalink )
Member Number: 53801
ID's are adjustable though. im pretty sure realtunes arent
#5 (permalink )
Member Number: 51197
Quote: Originally Posted by
19 psi
So...i'm wondering if the FIC and ID 900/1000 idle the same than.
DJOrtiz
or 16 whatev
WTB: LCA bushings
10-31-2009, 02:50 PM
#6 (permalink )
Member Number: 30696
Adionik
they are the same injector... FIC uses a different fluid then ID on there flow bench.
mine idle fine on both E-85 and on 92.
#7 (permalink )
bene
what do you mean by "adjustable"?
10-31-2009, 02:52 PM
#8 (permalink )
Senior Moderator SRT of the Month
Member Number: 39843
These don't need an injector driver or resistor box, right?
10-31-2009, 03:01 PM
#9 (permalink )
uncommon©
Supposedly they are direct drop ins.
1680cc idles make my head hurt.
So they're the same...damn! Realtunes 900cc plug and play is the same size as the ID 1000's than huh? If so you'd save like $100 in the group buy
#10 (permalink )
uncommon©
nope. no need for a driver box :-D
10-31-2009, 05:07 PM
#11 (permalink )
Member Number: 46349
bene
Ya what do you mean by adjustable.
05 Black SRT-4 ACR Almost there
10-31-2009, 05:10 PM
#12 (permalink )
So these are supposed to be 900/1000cc's at 43.5 psi, right?
Amdguy you're running these with 2 inline 255's and e85, right? What PSI?
10-31-2009, 06:02 PM
#13 (permalink )
uncommon©
im runnning them at ~50psi base with 1:1, i dont remember what my IDC where tho.
11-01-2009, 03:03 AM
#14 (permalink )
ive heard that ID's injectors are adjustable from 1000cc to 1600cc. i believe i read this in this section a few months back.
11-01-2009, 06:12 AM
#15 (permalink )
bene
Adjustable as in raising & lowering the fuel pressure.
amdguy
Awesome, thanks. I'll probably end up going with these over the winter.
Linear Mode
» Site Navigation
> Other Vehicles
» Buyers Guide
» Network Links
