Old 09-30-2009, 07:54 PM   #1 (permalink)
Member Number: 36585
Default injector duty cycle-scangauge
does the reading on the interceptor refer to how much of the injector you are using,
just-a-neon is offline   Reply With Quote
Old 09-30-2009, 10:51 PM   #2 (permalink)
apexcrazy's Avatar
Member Number: 24279
To quote the preacher from the Simpsons , "short answer Yes , long answer Maybe ."
The larger the duty cycle , the longer the injector stays open . The more fuel is delivered . You can push the injectors too far , they tend to not respond correctly .
At this point , I must state that what the scan gauge is displaying is not true duty cycle , it is usually higher than the true duty cycle seen at the injectors . The data displayed on the gauge is taken from the ECU , & it seems there are further calculations that occur after the point the data is pulled for this displayed parameter . Some people have seen values well above 100% . which is simply not possible . So while this is not a true reflection of duty cycle at the injector , it is a indicator as to what is going on inside the ECU , for what that is worth .
_____ _____
apexcrazy is offline   Reply With Quote
Page generated in 0.11101 seconds with 13 queries
