Old 11-02-2009, 03:44 PM   #1 (permalink)
phs17's Avatar
Member Number: 67384
Default how much boost can i run ?
i wanna kno how much boost i can run on stage 1 pcm , stage 1 injectors, on a stock turbo ?
phs17 is offline   Reply With Quote
Old 11-02-2009, 03:48 PM   #2 (permalink)
red04's Avatar
Member Number: 24993
Trader Rating: (49)
You want the peak at 18 psi and you will only be able to get 15-16 psi out of the stock turbo above 5100 rpms.
Scott @ Forward Motion Inc.
302-658-2829
www.forwardmotioninc.com
Email: scott@forwardmotioninc.com
Paypal Address: scott@forwardmotioninc.com
Owner of FM's GT37R powered SRT4 513 whp 469 wtq pump gas (93 octane) @ 6,000 rpms
11.31 @ 131.74 mph w/ 1.90 60'
red04 is offline   Reply With Quote
Old 11-02-2009, 03:50 PM   #3 (permalink)
phs17's Avatar
ok . yea im set at 18 now i just just wondering if i could could go above that and still be safe
Old 11-02-2009, 03:55 PM   #4 (permalink)
red04's Avatar
Trader Rating: (49)
I wouldn't as you won't get much more out of the stock turbo with more boost. Also with the way pump gas is these days.
Old 11-03-2009, 01:36 PM   #5 (permalink)
ticaaal70's Avatar
Member Number: 64715
Trader Rating: (24)
Just get 650ccs and the E1 or S3K with the FM Wga.
ticaaal70 is offline   Reply With Quote
Old 11-03-2009, 03:38 PM   #6 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
if your looking to find a few extra ponies try a tuneing device, more specific the DSP (and a WB if you dont already have one) that will give you the option of unlocking some hidden power. but be prepared to spend between 5-600 bucks on a WB/DSP combo
IMO you have the stocker maxed out and adding more boost or parts to an untuned car is like trying to start a fire with water, if you dont wanna spend the money just leave it where its at
Old 11-03-2009, 05:44 PM   #7 (permalink)
atenzany62's Avatar
Member Number: 70786
what about stage1 pcm with stage 2 injectors on stock turbo? can i make it spike 20 and i dont mind it dropping back to 15 cuz all stock turbos do that.
05 SRT-4
Mopar stage 1 with bolt ons.
Journal for my car
http://www.srtforums.com/forums/f41/...silver-540760/
atenzany62 is offline   Reply With Quote
Old 11-04-2009, 12:00 PM   #8 (permalink)
Member Number: 76002
Default hai
You want the peak at 18 psi?
CarsAddict is offline   Reply With Quote
Old 11-04-2009, 12:09 PM   #9 (permalink)
PsychoSRT05's Avatar
Member Number: 28174
Trader Rating: (12)
Stay at 18 psi until you get 3 bar sensors. You'll need 'em.
PsychoSRT05 is offline   Reply With Quote
Old 11-05-2009, 06:56 PM   #10 (permalink)
phs17's Avatar
so if i get 3 bar sensor i can run more boost
Old 11-05-2009, 07:52 PM   #11 (permalink)
d_fl8ted1's Avatar
Member Number: 11549
Trader Rating: (81)
When i had your setup i spiked 20 and fell to 17 psi for well over a year and then went big turbo... i also had a 75 wet shot on top of that...
stage 1 ecu
stage 1 injectors
cold air
stock exhaust
agp wastegate
greddy profec b spec 2 controller...
oh and a 255 walbro
On the 8th day GOD created drag racing
d_fl8ted1 is online now   Reply With Quote
Old 11-07-2009, 05:38 PM   #12 (permalink)
Member Number: 52541
Not really, they are definately a worthwhile upgrade but not NEEDED for that boost level
___________________________
2003 Solar Yellow - DSP, Meth & Boltons
dabezt1 is offline   Reply With Quote
Page generated in 0.13723 seconds with 13 queries
