Old 09-13-2008, 03:18 PM   #1 (permalink)
Member Number: 4648
Default how lean can you run e85
Ive been doing a lot of research lately on this fuel and i have yet to find out how lean is safe for e85.
currently I'm running 650cc injectors and getting no kr at all. timing is 28.5 during spool climbing to 32*+ at redline @20psi on stock turbo.
i've tried plenty of mixtures and finally found the right mix for the car.
Just wondering how lean we can go. From my understanding e85 is around 105 octane rating.
The car absolutley loves e85 mix.
right now the af's are 12.0 to 12.2 with no kr.
thanks in advance for input.
p.s. gas mileage is not as great with e85. im getting about 50miles less per tank.
JnR
Chase for 10's in norcal is on
for DSP NEEDS PM only: Turbo66, Mindmelt,
reed32 is offline   Reply With Quote
Old 09-13-2008, 10:25 PM   #2 (permalink)
Member Number: 18856
i wouldn't go any higher than 12.5 on full boost. i typically try to keep it as close to 11.5 with straight e-85.
not a thing just another slow a$$ neon
joe smalls is offline   Reply With Quote
Old 09-14-2008, 02:55 AM   #3 (permalink)
Member Number: 4648
i never take the cars to the 12.5 range. i still think i need larger injectors than te one's im running because i'm only pulling like 6%
JnR
Old 09-14-2008, 06:37 PM   #4 (permalink)
i run 1000cc was running out of fuel up top was at 120 duty on the injectors. so i upgraded the fuel system with -8 line a regulator bigger pump and rewire.
Old 09-14-2008, 07:22 PM   #5 (permalink)
Member Number: 4648
damn. what turbo you running?
JnR
Old 09-14-2008, 09:25 PM   #6 (permalink)
Member Number: 52801
i think lambda for e-85 is 9:1 gas is 14.7:1. so i think 12.5 on e85 is super lean.
AGP 3147, BOOMBA THROTTLE BODY, 3IN TBE, DW 750'S, WALBRO 255, RETURN LINE, MSD DIS 2 AND WIRES, ED HARD PIPES, ED CHARGE PIPE, HKS BOV, BFG DR'S ON ROTA'S, MOPAR STS, AEM WIDE BAND, AEM TRU-BOOST, AEROFORCE SCANGUAGE, SNOW PERFORMANCE STAGE 2, CAI
EDOGSRT is offline   Reply With Quote
Old 09-15-2008, 12:11 PM   #7 (permalink)
precisionsc61
Old 09-15-2008, 12:17 PM   #8 (permalink)
NeonDan's Avatar
Member Number: 138
funny thing is on 40/60 mix (e85/93 pump) stock turbo SRTs will see pretty decent power gains at 10.8-11.5 AFR...i havent tried 50/50 because i need more injector
Old 09-15-2008, 12:20 PM   #9 (permalink)
here is a article hopefully it helps.
E85 in standard engines - Wikipedia, the free encyclopedia
Old 09-15-2008, 12:39 PM   #10 (permalink)
ayoungblood's Avatar
Member Number: 7132
7.5:1 on E85 should be good according to that article...
2k4 Srt-4
ayoungblood is offline   Reply With Quote
Old 09-15-2008, 01:55 PM   #11 (permalink)
ziggo0's Avatar
Member Number: 63759
So you can run e85 mix in a stock SRT ?
Old 09-15-2008, 01:58 PM   #12 (permalink)
NeonDan's Avatar
Member Number: 138
with bigger injectors than stock...yes on stock injectors you wouldnt have a enough fuel to run anything more than a 15-20% E85 to pump mix. The rule is to run e85 is that you need 20-30% larger injectors or use a conversion kit
the car i posted about is running s2 injectors and s1 pcm but i need more injector given the mods. Car made 295whp/280wt @ 14psi on a 40% e85/60% pump mix....AFRs pegged in the 10s
Old 09-16-2008, 12:53 AM   #13 (permalink)
Member Number: 4648
no. the car will run to lean. ive tried it already and a/f's went 13's..
JnR
Old 09-16-2008, 12:57 AM   #14 (permalink)
Member Number: 4648
Dan tonight i took my shop car out and went to grab some e85. This car has HOM AND GUESS WHAT? HOM STAYED ON DURING ALL THE PULLS .
22 BUCKS TO FILL UP THE TANK WITH MY MIX
TIRES LITE UP BAD
JnR
Old 09-16-2008, 04:43 AM   #15 (permalink)
SRT of the Month
turbo666's Avatar
Member Number: 25206
Go to Evo forums, LOTS of E85 info over there. I have a buddy with an Evo on E85 and he made 456 on Buscher's dyno on a FP Red. Another one with a 35R that made almost 600whp on just E85 at a local dyno, that thing will lite the tires up in 1st! They keep there afr's around 11.5, they tried 12.0 but stared getting knock. Some of the E85 guys are doing high compression builds now, like 10.0:1! That's crazy, but I know one guy made over 1000awhp with 10:1 and E85.
If E85 was more prevalent in this area I'd switch to it, but only 1 station within 50 miles.
Nigel
04 Srt-4-CHANGES UNDER WAY..., 10.75@132 w/2.0 60ft, First to go 10's on stock bottom!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
IN-HOUSE MUSTANG DYNO for your SRT-4 tuning needs
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
