Old 10-11-2009, 04:47 PM   #1 (permalink)
Boosted-srt's Avatar
Member Number: 21562
Default High imp. low imp. Injectors WTF? Whats the best?
Im upgrading to S3, with a ported and polished turbofold, and a 47lb wheel. My fuel setup now cant keep up with the 20 psi i'm running on the stock turbo. I'm installing a Walbro 255 and a rewire.
Question; Are the low impedence injectors any better than the regular high impedence ones? Who makes the best quality injectors for the SRT-4? If I need to get the low impedence, where do I get the resistor box for them?
Opinions are greatly appreciated.
GET REAL....GET MOPAR
'03 Black, S2/Toys, AGP 3" CAI, 3"DP/No CAT, 3" side exit, Ultimate Racing hot and cold side/Greddy TypeS, Lorenzo 60mm TB & Spacer, FBM P&P Intake Mani., MAD-DOG 50% STS, Booger Bushings, 18" ADR Propulsion w/245/40/ZR18 tires, Willwood Big Brake Kit/Red calipers/Cross drilled and slotted, Mopar Performance 4-Puck clutch/Fidanza Aluminum Flywheel, AIS BFMIC/blacked out.
Boosted-srt is offline   Reply With Quote
Old 10-11-2009, 04:51 PM   #2 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
you need high impedence injectors
AGP S256 FS
Old 10-11-2009, 04:55 PM   #3 (permalink)
is that because you only sell high imp. inj.?
whats the warranty or garantee on yours?
Old 10-11-2009, 04:58 PM   #4 (permalink)
lyncoo's Avatar
Trader Rating: (92)
no you suppose to run high impedence injectors upto 1000cc. let me get the warranty facts for you.
Old 10-11-2009, 05:04 PM   #5 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (204)
what size injectors are you looking for?
PT-Performance.com
no resistor box needed.
PnP
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity
For SoCal guys only! Now offering JD-M Specials!
Old 10-11-2009, 05:06 PM   #6 (permalink)
lyncoo's Avatar
Trader Rating: (92)
650' would be great
Old 10-11-2009, 05:06 PM   #7 (permalink)
lyncoo's Avatar
Trader Rating: (92)
pm sent
Old 10-11-2009, 05:35 PM   #8 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
our cars can ONLY handle high imp. injectors (without a driver or resistors) if you usle low imp. injectors you will burn out the ECU
low imp. injectors by nature are better, they have less open/close delay allowing them to be used at lower PW, they are more accurate
some high imp. injectors are close to the performance but for now low is better
that being said what YOU need will be dependant on the application IE: buying low imp. injectors just cause they have a tiny (and it is miniscule) advantage is just plain dumb, now the nature of the allows more fuel flow BUT there is a limit if they are too big they will not be able to idle or have any control in the lower PW area
so get what fits..........
Old 10-11-2009, 06:26 PM   #9 (permalink)
Noted...thanks.
Old 10-11-2009, 06:27 PM   #10 (permalink)
lyncoo's Avatar
Trader Rating: (92)
<3 nutz
Old 11-04-2009, 12:38 PM   #11 (permalink)
Member Number: 76002
Default hai
May i know whats the warranty on this?
CarsAddict is offline   Reply With Quote
Old 11-05-2009, 04:40 AM   #12 (permalink)
NachO_SRT's Avatar
Member Number: 8662
Only one correction in this thread.
Low imp = faster is not "always" true
Low imp injectors can work faster in the lower pressure ranges, once you are at 55+ psi the advantage of the Low impedence is negated by pintle pressures, this will slow the injector down on the "close" cycle.
High impedence injectors are generally unaffected by fuel pressures up to 70 psi or so. After that normal injectors start to flake out.
These are the exact reasons I went with Injector Dynamics - They are made for high fuel pressure and are plug and play with our stock harness and rail fitment.
Have a read here: Injector Dynamics Finish that page and you will get an idea of what is up.
NachO
Daily Driver -2009 SWP WRX STi + Gold BBS's
Road Course Car. 2004 E-blue SRT-4, Mods and pics: CLICK
7/18/09 - 507/468 - S259 Fuel E85 - Meanblueberry.
STOCK:308/396 - 5/17/2009 E-85, Stock turbo
NachO_SRT is online now   Reply With Quote
Old 11-05-2009, 04:01 PM   #13 (permalink)
4drsportscar's Avatar
Member Number: 13792
Is this what I want for E85 and a delta 48?
http://www.t1raceparts.com/en/produc...ector-set.html
AGP hot and cold ic pipes, Needswings v6 dp, mccord plate, Auto meter EGT and wide band, Magnaflow ext,BFMIC,AGP dog bones and trans mount, AGP wast gate,S1, WOT box, DSP.
4drsportscar is offline   Reply With Quote
Old 11-08-2009, 02:59 PM   #14 (permalink)
Bump please
Old 11-08-2009, 08:36 PM   #15 (permalink)
NachO_SRT's Avatar
Member Number: 8662
Quote: Originally Posted by 4drsportscar View Post
Bump please
The injector you want is known as the "ID 1000"
http://www.t1raceparts.com/en/produc...cs/id1000.html
You need to call T1 and request the SRT-4 Kit - it should include - 4 connectors (you will not need) - 4 injectors (you will need) - A sheet of paper with the Usec/Deadtimes/Flow numbers on it (your tuner will need) - and a tidy little white box that is amazingly non-descript.
I also know a shop that sells the ID 1000's for the SRT-4 - in stock last time I checked. They do not vendor here so PM's for details.
NachO
Page generated in 0.18492 seconds with 13 queries
